Decent sound in a BA ?
KAL_SPL
  • Member For: 16y 6m 2d
Does anyone have any pics of systems that have been done in BAs or details on what you have done to increase the output of the standard system ?
Iran a 4 gauge wire for my v12 alpine amp,which powers me 12" cerwin vega sub,did all the wiring myself,took me atleast 10 good hours...end result was worth it,now my system has loud punchy bass....makes rear view mirrow vibrate like a mofo :)
  • Replies 41
Posted Images
  • Member For: 18y 6m 5d
To get the resonate frequency of a car , you use a sound field generator and a spl meter. By doing frequency sweeps you can as certain 2 resonate frequencies. One will be the resonatee frequency of the car nad the other will be the resonate frequency of the Sun/box. I have found that most cars resonate frequency is around 60-65Hz. This is then what you tune your port frequency to.
To gain 3 db in any sub system. You have to either double the power going to the 1 sub. Or add another sub (Same type) running at the same power to gain 3 db. But!! There is another way to gain 3 Db that is completely free. It is called woofer loading. Here is a simpple test for you... Go to your home system and turn it on at a reasonable level. listen to it and themn turn the speaker around to face the wall leaving about a 6 inch gap between wooofer and wall. Hear the difference. Like I said earlier. this will gain you 3 Db. Loading a woofer into 2 surfaces. Such as loading it at 45 into a surface (eg floor and wall) will gain you 6 db.
I have to go to work. So this is a limited response. I will hopefully get back tonight to finish.....
