Which oil?
ex-are-six
  • Member For: 20y 10m 1d
Picking up delivery of Redline 10w-40 next week before 15k service, reason being as I'm a field tech I'm on the road most of the time and give the T heaps between jobs, problem is about a min after getting back into the car I can small this burnt smell, dunno if its oil cookin after switching her off as the T has no turbo timer or if its from the air con, you can only smell it for a few seconds then disappears, anyway going the Redline next week.
Why are you going to start using the wrong viscosity?
I think using the right viscosity is more important than the brand.
I spoke to peter warren, and they tell me they use Shell Helix Plus (15W/50) - semi synthetic
that's what ive used in my car
PS - Changing the viscosity of the oil at higher temps (ie, in my case the 50 from 40) isnt bad because it just means that the oil will flow better at high temps. What I have found out (through reseach and speaking to various people) is that you should leave the viscosity at low temps as is recommended by the manufacturer (is the 15). It seems that anything under that is a bit too thin for cold starts and is meant to be bad for the engine (ie, not enough lub)
I dont know how correct that statement is, please correct me if I am wrong.
From what I have researched when changing the oil in my NA xr6 using a lower start up viscosity oil helps on start up as the oil circulates more freely and hence faster when the oil pump pushes eveything up top?
  • Replies 26
  • Member For: 21y 10m 16d
gt3 and magnetec are mineral oils, formula r is synthetic.. I talked to castrol tech department not a rep.. from experience the reps know s%$#.... my turbo rebuilder recommend synthetic not mineral..The only thing castrol suggest is change oil to synthetic between 5000km and 10000km... Turbo rebuilder say change to synthetic before 15000km. Everyone has there own opinion and choices it all depend on who you trust the most... ;)
  • Here since the start...
  • Member For: 21y 9m 5d
Well I trust Ford and they recommend 15W-40, and I wouldn't use anything else. Even APS said at the Melb. day that use whatever brand you like but stick to the 15W-40 grades. Your right everyone has there own opinions. :ta:
Guest Big Mick
  • Guests
It's interesting to note that in the manual Ford says for best fuel economy use 15W-40.
It doesn't say that this is the best grade for maximum engine protection.
  • Member For: 21y 3m 25d
Hi Guy's,
The oil debate is frustrating, appreciate the input from DaveWA and co who are in the trade and know more than the the rest of us, :holiday:
Adding my 2 centipoise worth, agree to keep the viscosity to 15W40, but struggled to find a synthetic that had the spec.
Ended going with Motul 300V which is 15W50, fully synthetic. figured that the 50 gives better protection at higher temps.
DaveWA, would you agree with this?
Downside....$150 for 2x4 L at Autobarn :beerchug:
Anyone know where you can get a 15W40 fully synthetic in Melb (like Penrite Synth 5) or alternative,
Thanks in advance,
Rick
OK adding more oil to the fire.......... :lol: ... Done some phoning ,emailing ,etc... this quote from CASTROL.....The viscosity specifications on the BA XR6 Turbo are for a API SJ SAE 15W/40.
Hence a 0W/40, 5W/40 & 10W/40 oil would be acceptable.
As retail packs (oils available in 5L containers from regular retail outlets), GTX 3 (mineral API SL SAE 15W/40), Magnatec (which is a semi-synthetic API SL SAE 10W/40)
and Formula R Synthetic 0W/40 (API SL full synthetic) would meet those requirements. On overall performance, would probably overlook GTX 3 in favour of Formula R or Magnatec.
Magnatec 5W/40 SP is a trade oil (not available through regular retail outlets, available only in larger container sizes like 20L & 205L, available to dealerships & workshops).
It is a synthetic SAE 5W/40, based on similar chemistry to the retail Magnatec and is also suitable for the XR6 Turbo.
Huh :blush:
15W40 is not the same as 0W40,
Other threads covered this, DavoWA has written this up from an insiders point of veiw,
I was hoping to get confirmation that the 15W50 Motul I used would be ok, suspect it is as it meets all the ford requirements in terms of standards, and being a W50 should be a little better at high temps. :blush:
Your thoughs? :hrmm:
