reverse sensing system
NYOPA
  • Replies 40
Posted Images
  • Abuser of Charvels
  • Member For: 21y 1m 19d
Check this out. I emailed these guys ages ago but I can't remember a price. I'm pretty sure it was cheaper than the Ford system and you can install it yourself. Also, no ugly bullet holes in the back of your car!!
Click Me
I just had a chat to these guys. The system is available thru Repco for $250 and you can install it yourself, or get someone to do it.
I asked about front mounting and you can do it and you'd need to install a switch to turn it on when needed, as the reverse one is activated when you go into reverse and gets power from the reverse lights.
Looks very interesting, you can get the front and back of your car covered for less than the factory one and no holes.....hmmm....
  • Team Blueprint
  • Member For: 21y 2m 11d
:thumbsup:
Once again everyone comes through with some really usefull advice.
If anyone else knows of any other systems please let me know.
  • Member For: 21y 3m 30d
Hi Guys,
I am developing an interface to connect between your factory fitted reversing system and the premium ICC.
This will give you a graphic representation of how close you are to an object with more accuracy than just the beeper. The display will show distance from each sensor (4 of them) and beeper will remain the same.
This should be a very easy add on to your vehicle.
I will keep you informed.
Cheers.
(An aftermarket kit will also be developed using the Bosch Park Pilot system.)
