  • New Member
  • Member For: 3y 3m 13d
My car has developed a creaking sound in the rear left hand corner of the vehicle only noticeable when accelerating out of a left corner.
I just changed out my control blade bushes from the flogged out factory units to the superpro control blade bushes. I also recently just had the tail shaft
out of the vehicle to get a new centre bearing and balance. So the only difference to the car is the removal of the blade arms and reinstallation with new poly bushes
and the removal of the tail shaft and reinstallation with new centre bearing. I put the car on ramps and tightened the control blade arm bolts up while the suspension was under load
and checked my wheel nuts. It does not happen when turning right nor is there any sound coming from the right side of the car. I will be able to put my car on the hoist at work tomorrow
to have a proper look but can anyone help with direction for troubleshooting.
thanks
https://www.fordxr6turbo.com/forum/topic/97405-creaking-noise-coming-from-rear/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 12d
does seem pretty likely that the bushes were slightly incorrectly installed or are just transmitting more NVH than previously...
  • New Member
Yeh I will have a proper look on the hoist and might pull the control blade off and make sure the new bush is seated properly with enough
grease. Apart from doing that I suppose it may just be the different style of bush.
