  • New Member
  • Member For: 22d
2006 BF FPV Force 6
While driving at around 10kph or less and sitting stationary, my force 6 will consistently pop the 15a Ignition fuse when applying the brakes
Started the morning of all ford day in geelong after already driving the car for a couple of hours prior.
I had a similar problem about 18 months ago that turned out to be a factory sleeved ignition and boost control wires coming out of the ecu that had rubbed through on the top of the strut tower
this was repaired and another ecu was married to the car, for some reason the origional ecu had become faulty and could not be tuned via pcmtec after that wire issue
I doubt that it has anything to do with it but any electrical issue with the car has been AFTER the stage 3 zf trans tailshaft and trutrak/ims hat was installed and tuned ( then driven for a year )
has anybody else had this problem
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 6d
seems like something an auto-elec should be sorting out... seems a bit complicated, if it happens when you apply the brakes 😮
