rapidyellowxr6t New Member 16 Member For: 3y 4m 26d Posted 24/02/25 09:05 PM Share Posted 24/02/25 09:05 PM Hello brains trust. I have been having intermittent starting problems with my 2005 ford xr6 turbo. The car was ran very low on fuel in December last year and had subsequent issues starting. It blew a couple fuses but seemed to sort itself out (or so I thought). Initially had put it down to contaminated fuel and a dicky relay. The problem has now reared its head once again where the car would completely not start this morning nor the accessories come on. With cycling the key I can hear in the IAC clicking repeatedly and once I disconnected that loom it was the fuel pump relay repeatedly clicking. Upon inspection the fuel pump relay has completely been melted and has damaged my fuse box terminal where the relay should go. It’s clearly shorting out and causing different components to cycle their processes. What do I need to do to properly diagnose this issue. Link to comment https://www.fordxr6turbo.com/forum/topic/97390-melted-fuel-pump-relay-and-persistent-fuel-pump-issues/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,586 Member For: 17y 2m 25d Gender: Male Location: Melbourne Posted 24/02/25 09:46 PM Share Posted 24/02/25 09:46 PM well, the relay "melting" is probably caused by an a short-circuit upstream of the relay which presented in the relay itself... or just the relay itself... I assume you've replaced the fuel pump relay and cleaned up the terminal? that'd be the first step... Link to comment https://www.fordxr6turbo.com/forum/topic/97390-melted-fuel-pump-relay-and-persistent-fuel-pump-issues/#findComment-1725668 Share on other sites More sharing options...
rapidyellowxr6t New Member 16 Member For: 3y 4m 26d Posted 25/02/25 02:22 AM Author Share Posted 25/02/25 02:22 AM That is the plan tonight after work. If the short circuit is coming from upstream of the relay what else do I need to check. Is there a way to check the fuel pump to see if it’s drawing too much current (walbro 340). I also assumed that the fuel pump fuse would have popped before the relay would get so hot and damage the fuse box. Link to comment https://www.fordxr6turbo.com/forum/topic/97390-melted-fuel-pump-relay-and-persistent-fuel-pump-issues/#findComment-1725674 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 12d Gender: Male Location: Perth Posted 01/03/25 03:52 PM Share Posted 01/03/25 03:52 PM Did you fix it? Running the pump low has probably cooked it causing it to draw more current. Keep in mind a 10 amp fuse is desgined to support its rated currenr as a constant and not blow at that rating. Some fueses will support 25 to 50% above rated current to prevent fuses blowing on a minor current spike. Down side is this can allow the circuit to run on the top end of it's capacity resulting in meltage Link to comment https://www.fordxr6turbo.com/forum/topic/97390-melted-fuel-pump-relay-and-persistent-fuel-pump-issues/#findComment-1725714 Share on other sites More sharing options...
