Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 16/02/25 05:03 AM Share Posted 16/02/25 05:03 AM For now you might get away with replacing the 525 for a 460. It won't melt the wiring like that. Can get whole pump and pot assemblies from eBay for about $400. Just drop it in and go. Link to comment https://www.fordxr6turbo.com/forum/topic/97389-melted-connector-in-525-fuel-pump-assembly/page/2/#findComment-1725634 Share on other sites More sharing options...
Seears Member 11 Member For: 14y 1m 16d Gender: Male Location: Canberra Posted 16/02/25 07:22 AM Author Share Posted 16/02/25 07:22 AM (edited) Thanks mate I thought I had done the right thing in terms of future proofing the fuel system by getting the 525 drop in, regulator and wiring kit My mechanic ordered a standard assembly from repco yesterday that should arrive on Wednesday. I could return it and get the drop in instead but I had actually bought a 460 a few years ago and never used it. Would it be a case of switching the pump that comes with the new assembly with the 460 I have in the garage? edit: reading some other threads I think if I switch the pumps I will need to dremel the housing bit to fit the larger pump Edited 16/02/25 07:27 AM by Seears Link to comment https://www.fordxr6turbo.com/forum/topic/97389-melted-connector-in-525-fuel-pump-assembly/page/2/#findComment-1725636 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 16/02/25 08:17 AM Share Posted 16/02/25 08:17 AM There's plenty of info on here how to fit a 460. For the amount you're gonna get shafted by Repco, you may as well get a drop in unit from eBay. While we're here, you could just drill some holes through the top of your burnt pot, run some 6mm wire through to the already installed pump and silicone it shut around the wires. You'd just use the relay output to go straight to the pump, instead of the connector. Easy as with some spade connectors etc. Still gotta run the connector for the fuel level sender. There's plenty of ways to go about it, just gotta juggle the options and see what's best for you. Link to comment https://www.fordxr6turbo.com/forum/topic/97389-melted-connector-in-525-fuel-pump-assembly/page/2/#findComment-1725638 Share on other sites More sharing options...
Seears Member 11 Member For: 14y 1m 16d Gender: Male Location: Canberra Posted 16/02/25 08:30 AM Author Share Posted 16/02/25 08:30 AM I will have a think on it. I will probably get the eBay 460 assembly and be done with it. It’s been off the road for over month now so a couple more days waiting for it to arrive won’t matter thanks for taking the time to type that out for me 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97389-melted-connector-in-525-fuel-pump-assembly/page/2/#findComment-1725639 Share on other sites More sharing options...
