F6 swap to na chasi
Jayden7676
  • Member For: 2y 9m 12d
I swaped over the f6 , done all internals to engine all was well to first drive,  is making a out the gate noise from front left side , I don't think I can attach file of it as it's to big but do you have a fb I can send it to or something try get a diagnostic on it ? Sounds like if you put a bottle in spokes on a push bike not quite as Loud as that but sounds like a duller version of that.  When car is stationary can rev it with no abnormal sounds , as soon as I'm moving under load it does it ,
Have raised it of the ground and put in drive and it has not made the noise atall smooth as butter,  applied hand brake and making a wicked knock from rear left and side brake , brembo chances it's shuttering through the car due to abs working its job? Only happens after 2krpm while driving on the road
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 14d
so it still does it elevated with the handbrake applied? localised the sound to the rear-left for sure?
  • Puff
  • Member For: 10y 26d
Check the wheel nuts are tight. If you run it on a dyno, not flat out obviously, you will be able to see what is making the noise. Will only cost a couple hundred tops.
Edit: sounds like it is the plastic inner guard rubbing
Edited by Puffwagon
My balls
Found it was a bolt in subframe completely missing went and got one and nipped it up , sound gone. Was the rear left so was definitely that side just wasn't the brakes as first thought stoked its sorted what a blody project that's been.  Running great now no codes ect.  New turbo and fule system on the way hope to make 450 then cert , exciting
