Joshua Giles New Member 5 Member For: 1m 18d Posted 07/01/25 01:02 AM Share Posted 07/01/25 01:02 AM Just wondering if anyone could point me in the right direction, Got a MK2 FG XR6 Turbo, I was playing around with some fuses in the fuse box last night just trying to see if I could get an aftermarket electronic accessory to work it sort of just randomly stopped working sometime ago. After having done that I tried starting the car and it throws a Transmission Fault and DSC Fault and the cars stuck in limp mode. I've charged the battery and have checked my fuses and they appear to be fine. I have also tried replacing my battery but it didn't make a difference. Anyone got any ideas? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,256 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 07/01/25 02:26 AM Share Posted 07/01/25 02:26 AM check the codes on the OBDII connection and go from there... One simple thing you can do is disconnect the battery for 30min+ and then try again. Link to comment Share on other sites More sharing options...
Joshua Giles New Member 5 Member For: 1m 18d Posted 07/01/25 02:30 AM Author Share Posted 07/01/25 02:30 AM I bought a cheap OBD2 scanner but it displayed no error codes sadly Ive also just tried replacing the brake switch sensor and thst hasnt helped either Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,256 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 07/01/25 02:41 AM Share Posted 07/01/25 02:41 AM Try the long-term battery-disconnected thing. Link to comment Share on other sites More sharing options...
Joshua Giles New Member 5 Member For: 1m 18d Posted 07/01/25 02:42 AM Author Share Posted 07/01/25 02:42 AM I have tried that but I'll do it for longer I'll let you know how it goes cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,256 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 07/01/25 02:47 AM Share Posted 07/01/25 02:47 AM 30min may not be enough, overnight will surely reset it... but if that doesn't fix it then I'd suspect you need the help of an auto-elec. Link to comment Share on other sites More sharing options...
Joshua Giles New Member 5 Member For: 1m 18d Posted 07/01/25 02:50 AM Author Share Posted 07/01/25 02:50 AM I've just managed to fix it, double checked the fuse box and upon closer inspection one of the fuses had infact broken, now replaced with a fresh one and its up and running, an incredibly silly oversight on my part but Im just glad its not something bad. Thank you for your help it is much appreciated Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,256 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 07/01/25 02:52 AM Share Posted 07/01/25 02:52 AM oh, great news thanks for coming back to let us know what you did to fix it. Link to comment Share on other sites More sharing options...
