jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 12/12/24 09:47 AM Share Posted 12/12/24 09:47 AM Ba xr6t turbo seems to be drinking fuel lately...more then it usually does haha Anyway last week showed a code for trying to compansate for a overly lean condition so I changed 02 sensor. As it did say possible sensor issue... Today I decided to scan it again and only code it has in PCM is now a P1386 code.... timming over advanced bank 2. I cleared code. Took it for a drive for like 4 min and came back and no codes came up but I believe it will show back up again after a few drives. Does this sound like skipped chain? I'm Can a bad actuator solenoids or sensor cause these? Or should I try data logging if so what should I look for. I'm using forscan software if that helps It does drive ok..but kinda feels a bit down on power/response down low ..up high it seems to go better lol Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/ Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 12/12/24 10:25 AM Share Posted 12/12/24 10:25 AM (edited) Forscan will show cam error Edited 12/12/24 10:26 AM by Puffwagon Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725165 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 12/12/24 12:42 PM Author Share Posted 12/12/24 12:42 PM Thanks. Where in forscan will I see this? Is it when monitoring while running engine? Obviously I'll have to select it in settings Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725166 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 12/12/24 02:06 PM Share Posted 12/12/24 02:06 PM You go to read PID data which is the oscilloscope symbol on the left. At the top you select dashboard, then you have to manually add it by clicking set up all gauges down the bottom, it's the settings looking button, then you have to connect to there live data by clicking the play button... Or maybe the other way around, I can't remember. I'm not connected to a vehicle now but that is the gist of it. Yes it has to be running, the cam has dicks that go past the cam sensor. The pcm doesn't know the engine position until it's cranking, and won't know the cam error until it's running. Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725167 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 12/12/24 08:31 PM Author Share Posted 12/12/24 08:31 PM Thanks heaps. I will have to do some checking. I have been told by someone who tunes that a lazy vct solenoid could cause this aswell but was told to do exactly what you have told me to do (just didn't get told how to do it haha) Then I'll need to work out what it all means while monitoring it lol I'll get back to you once I have Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725168 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 13/12/24 02:52 AM Author Share Posted 13/12/24 02:52 AM Have done a small log. But U sure wtf I'm looking at really ...also while I was reving the engine gentlely at about 2200 rpm and took foot off accelerator slowly it stalled like instant stall...no splutter etc and wife also told me now it did same other day for her. But yeah the VCDADV2 and the VCDADV were both at like -9 to -10 at idle...when reved they did drop near to zero Vcadverr ones were basically 0 or went to 0.33 etc Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725170 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 13/12/24 03:40 AM Share Posted 13/12/24 03:40 AM If they are reading -10 at idle, something is farked. Check the solenoids are plugged in for starters, after that you will need to see a mechanic. Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725171 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 13/12/24 03:52 AM Author Share Posted 13/12/24 03:52 AM Hahaha So....it still drives etc but yeah that would explain fuel economy issue I guess 😂 It is a ba so they have the little plastic filter in cam cap for solenoids could they be blocked Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725172 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 13/12/24 04:58 AM Share Posted 13/12/24 04:58 AM I suppose they could be, you'd have to pull the front 2 cam caps and check. Don't pull them off unless you have a small torque wrench to do them back up, there is a very small window between done up enough and done up too much and the bolt is stretched. Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725174 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 30d Gender: Male Location: Maryborough Qld Posted 13/12/24 05:45 AM Author Share Posted 13/12/24 05:45 AM That's will do. Also do these filters have to be installed or can be left out? And also if it had low oil pressure could that be an issue? Surely I'd have other issues. I just say that as I read a post about someone have low pressure causing codes Link to comment https://www.fordxr6turbo.com/forum/topic/97370-ba-xr6t-p1386timming-skipped/#findComment-1725175 Share on other sites More sharing options...
