greasemonkey Member 97 Member For: 7y 7m 1d Posted 15/10/24 12:09 PM Share Posted 15/10/24 12:09 PM Hi guys Still plotting along with my repairs at the moment. Progress is when ever I have the time. Stuff with cars takes longer than you allow it too! One thing is that I noticed the metal pipe outlet at the thermostat is leaking. What is the best fix for this? See the picture (circled part) as a reference. Anyway I've researched and there is an o-ring that sits in this bugger however there is no mention to use RTV sealant. I pulled some off that was old and that is why it's leaking (clever me) Any help appreciated as always. Link to comment https://www.fordxr6turbo.com/forum/topic/97353-leaking-heater-pipe-at-thermostat-your-way/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 27d Gender: Male Location: Melbourne Posted 16/10/24 03:11 AM Share Posted 16/10/24 03:11 AM just unbolt it and have a look if it has an o-ring or a gasket and replace as necessary. Link to comment https://www.fordxr6turbo.com/forum/topic/97353-leaking-heater-pipe-at-thermostat-your-way/#findComment-1724640 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 8d Gender: Not Telling Posted 16/10/24 07:25 AM Share Posted 16/10/24 07:25 AM The o'rings go hard over time and leak slightly. With a trust 10mm socket, undo the retaining clamp, pull the tube out, remove the old o'ring, clean the pipe and the hole it goes into, give the new o'ring a touch of silicone spray to help it slide in, do it back up. Link to comment https://www.fordxr6turbo.com/forum/topic/97353-leaking-heater-pipe-at-thermostat-your-way/#findComment-1724642 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 7m 1d Posted 16/10/24 12:23 PM Author Share Posted 16/10/24 12:23 PM I'll get a new o-ring then. Hopefully they don't require any sealant after installed (it doesn't leak). Thanks Puff and Keith for the information. Link to comment https://www.fordxr6turbo.com/forum/topic/97353-leaking-heater-pipe-at-thermostat-your-way/#findComment-1724643 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 8d Gender: Not Telling Posted 16/10/24 12:55 PM Share Posted 16/10/24 12:55 PM They don't need sealant. Just make sure there are clean surfaces for it to seal against. Link to comment https://www.fordxr6turbo.com/forum/topic/97353-leaking-heater-pipe-at-thermostat-your-way/#findComment-1724644 Share on other sites More sharing options...
