Seears Member 7 Member For: 13y 5m 29d Gender: Male Location: Canberra Posted 11/09/24 01:55 AM Share Posted 11/09/24 01:55 AM (edited) Hey guys, I did a few searches and couldn’t find anything with the same issue. Last night I was taking out the turbo intake pipe and saw that the low beams were on and turned off by themselves. It’s not on the auto setting. Sometimes just the passenger side would come on and then both for a while and then off again. They keep intermittently doing that but not always just the one side, not really any pattern to it. I pulled the low beam relay out and still the problem persists. I disconnected the negative from the battery last night and then reconnected this morning but it had already drained so it doesn’t have enough charge to start. I’ve bought some new globes but I don’t see how they would be the issue if they still light up. Video is showing the issue: the lights are switched off but the passenger side turning on and then me switching the low beams on and then to off to show they both stay on. To confirm at the end of the video the lights are switched off. Has anyone had the same issue or have any ideas? Hope I’ve posted to the correct area. Cheers guys IMG_0298.mp4 Edited 11/09/24 01:57 AM by Seears Link to comment Share on other sites More sharing options...
Seears Member 7 Member For: 13y 5m 29d Gender: Male Location: Canberra Posted 11/09/24 05:38 AM Author Share Posted 11/09/24 05:38 AM I had forgotten that about 2 years ago I have swapped from the mk1 headlights to mk2 with the wiring kit to fit H7 bulbs. Remembered that just now and have removed the two 15 amp fuses in that wiring which has stopped them coming on but still have the issue as now I have no low beam. Thinking it has got something to do with the added wiring from the swap. Link to comment Share on other sites More sharing options...
