xr6tForMe Donating Members 248 Member For: 11y 2m 20d Gender: Male Posted 19/08/24 04:53 AM Share Posted 19/08/24 04:53 AM Our BA wagon had a few noticeable scratches on the windscreen from the wiper arm scratching the glass when a blade fell apart. They were not deep, but reasonably visible. I bought a cheap kit from ebay with a few polishing pads and cerium oxide powder and had a go at polishing out the scratches. It worked quite well. I just used a little 1" buffing wheel in a Ryobi cordless drill with a slurry of cerium oxide and went over the main scratches, then used a 2" pad to go over the main scratches as well as a wider area. The main scratches are gone which I am very happy about. Where I covered a wider area, it still needs more work to get rid of the very fine scratches that the wiper blades have left over the whole screen, but there is also a big improvement there as well. It is a slow process, but the results are good for removing fine scratches After 21 years there are also quite a few tiny little chips that are deeper, and I think they would not be removed without polishing all the glass down to the lowest point of the chips. I think they will be staying unless I try the very fine wet and dry sanding discs that came with the kit, but I do not like the idea of causing further scratches. If you like working on your car and there are scratches on your windscreen, I would recommend trying this yourself. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,751 Member For: 16y 5m 8d Gender: Male Location: Melbourne Posted 19/08/24 05:21 AM Share Posted 19/08/24 05:21 AM thread needs before and after pics Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 248 Member For: 11y 2m 20d Gender: Male Posted 19/08/24 06:42 AM Author Share Posted 19/08/24 06:42 AM Sorry, I did not take photos. I think it could be pretty hard to take good photos of scratches / no scratches, but I might see what I can do for photos next time. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,751 Member For: 16y 5m 8d Gender: Male Location: Melbourne Posted 19/08/24 11:28 AM Share Posted 19/08/24 11:28 AM all good mate, no worries Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 248 Member For: 11y 2m 20d Gender: Male Posted 20/08/24 08:36 AM Author Share Posted 20/08/24 08:36 AM I might see what I can do for photos next time. My FG seems to have more of the general wiper scratches across the whole screen, but, fewer bad scratches when compared to the BA. I am also curious what might happen using other items, like "cut and polish", "gumption" or "jif" compared to the "cerium oxide", so I might do some testing on some other glass. Link to comment Share on other sites More sharing options...
