g6e problems New Member 1 Member For: 1y 6d Posted 26/06/24 06:01 AM Share Posted 26/06/24 06:01 AM So I purchased sealed wheel hubs and brake rotors on ebay and installed them. The first drive for 10 minutes at 100km/h the wheel hub was smoking and really hot and the hub doesn't fit with the rotors the rotors said they fit fg xr6 and the hubs said they fit fg. Is there a difference and why is the stud holes too big in the rotor causing them to wobble and knock. What do I do? Do I just get new hubs to fit the rotors. Link to comment https://www.fordxr6turbo.com/forum/topic/97295-g6e-vs-xr6-wheel-hubs/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,584 Member For: 17y 2m 22d Gender: Male Location: Melbourne Posted 26/06/24 06:12 AM Share Posted 26/06/24 06:12 AM I'd check for runout where the hub and the rotor mount, just in case there's something there causing it to wobble. If they're made for your car, they should fit... if they're perfectly fitting and still causing problems I'd be contacting the seller(s) to confirm it's all correct equipment. Link to comment https://www.fordxr6turbo.com/forum/topic/97295-g6e-vs-xr6-wheel-hubs/#findComment-1723404 Share on other sites More sharing options...
xr6tForMe Donating Members 281 Member For: 12y 3d Gender: Male Posted 01/07/24 12:12 AM Share Posted 01/07/24 12:12 AM On 26/06/2024 at 4:01 PM, g6e problems said: So I purchased sealed wheel hubs and brake rotors on ebay and installed them. The first drive for 10 minutes at 100km/h the wheel hub was smoking and really hot and the hub doesn't fit with the rotors the rotors said they fit fg xr6 and the hubs said they fit fg. Is there a difference and why is the stud holes too big in the rotor causing them to wobble and knock. What do I do? Do I just get new hubs to fit the rotors. Have you compared the new hubs and rotors with the old ones? Were the parts you bought just standard replacements? Are you sure it was the hubs that were smoking and not the brakes? What did it smell like? Is there any drag if the wheel is off the ground and you try spinning it? Link to comment https://www.fordxr6turbo.com/forum/topic/97295-g6e-vs-xr6-wheel-hubs/#findComment-1723456 Share on other sites More sharing options...
