ltca New Member 3 Member For: 1y 3d Posted 11/06/24 03:57 AM Share Posted 11/06/24 03:57 AM Hi All, I've got a set of mustang rims for my BF Falcon - yes, I'm aware the offset is way out of wack, I'm getting spacers machined to fixed that. My question is - what offset is ideal for 19x9.5 rims? For whoever runs them, would I be able to get away with 35 or would I need to go down to 20/25. Cheers guys. Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,544 Member For: 17y 2m 4d Gender: Male Location: Melbourne Posted 13/06/24 11:35 PM Share Posted 13/06/24 11:35 PM ' 19x9.5 basically won't fit on the front of a B-series falcon without camber and/or majorly rolled+pumped (or in the extreme, cut and flared) guards unless you have ridiculous guard gaps (e.g. really high suspension, possibly even higher than OEM...). To clear the front suspension upright you need an offset of 25 or lower (e.g. can't go 26+ offset, as 25 offset is ~6.5mm closer to the suspension upright) as there's ~7mm of gap between an OEM 8" wide rim with it's 37.5 offset. For the outer clearance you have ~9mm with OEM guards (e.g. not rolled) and 9.5" pokes a lot more (~32mm extra) even at perfect inner offset of ~25: https://www.willtheyfit.com/index.php?width=235&aspect=45&diameter=17&wheelwidth=8&offset=37.5&width2=245&aspect2=35&wheel_size=19&wheel_width=9.5&offset2=25 For the rear, you can go up to 48 offset as that would sit ~29.6mm closer to the rear suspension trailing arm and you have ~30mm of space there with the OEM 8" wide rims with their 37.5 offset. Depending on what offset you go you can have the rims more flush etc as you have ~15mm of clearance in OEM form to an unrolled guard. https://www.willtheyfit.com/index.php?width=235&aspect=45&diameter=17&wheelwidth=8&offset=37.5&width2=245&aspect2=35&wheel_size=19&wheel_width=9.5&offset2=48 You can see how hard I had to work to fit a 20x9 on the front of my car without camber... lots of rolling and pumping and it still hits the guard in extreme scenarios https://www.fordxr6turbo.com/forum/topic/96768-tsw-bathurst-on-ba-xr6t-f20x930r20x1040/ Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/#findComment-1723243 Share on other sites More sharing options...
ltca New Member 3 Member For: 1y 3d Posted 24/06/24 08:03 AM Author Share Posted 24/06/24 08:03 AM You gave me everything I need, thank you so much for that! Good news is I didn't know that the fronts were staggered, fitting at 19x9, meaning that I can defs work the fronts to fit. I talked to my tyre shop and they reckon I can get by with 19x9 fronts with 32.5mm offset, this means I only have to run generic 20mm spacers to offset the 52.5mm it comes with. Even though its 7.7mm closer in, I'll see what fiddling I can do for it to clear properly. Fingers crossed. Your other post helps heaps too to put me on the right path. Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/#findComment-1723376 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,544 Member For: 17y 2m 4d Gender: Male Location: Melbourne Posted 24/06/24 10:46 AM Share Posted 24/06/24 10:46 AM No worries, happy to help yeah, that 7.7mm closer on the front-inner might require some dodgy stuff to get it to work... a 20mm spacer isn't a great solution... but no more dodgy than trimming a control arm to clear the 7.7mm... Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/#findComment-1723379 Share on other sites More sharing options...
ltca New Member 3 Member For: 1y 3d Posted 25/06/24 01:05 AM Author Share Posted 25/06/24 01:05 AM Yeah its a bit dodgy, another problem I'm racing due to my limited actually reading of the rims is the fact that the fronts are 9' ET 45, 20mm will get it to +25 but I am assuming that theres no possible way to get that 9' +25 to work without major guard destruction, my final question is what is the offset range for a 19x9 to fit? It'll be ~25.2mm sitting out extra. Appreciate it! Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/#findComment-1723383 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,544 Member For: 17y 2m 4d Gender: Male Location: Melbourne Posted 25/06/24 01:24 AM Share Posted 25/06/24 01:24 AM 9" MIGHT work with +32 (but it also might hit the inside). 9" with +31 will clear the inside (with a minimum of +18.2mm on the outside) The +25 you are talking about can work, with a LOT of guard work, or really high suspension that never gets close enough to hit the guard Link to comment https://www.fordxr6turbo.com/forum/topic/97284-bf-falcon-rims-and-tyres-questions/#findComment-1723384 Share on other sites More sharing options...
