Oxygen sensor issue ?
Nick_is_not_sus
  • Member For: 1y 2m 19d
Was playing around with my mates tool pro OBD scanner thing, was just curious on how well they worked I have a Xtool D7
anyway ive never checked this before there was a 02 sensor test sso I thought ill check it out
rich to lean sensor (v)
test ID  #01
test value 0.4499v
minimum limit 0.4499v
maximum limit 0.4499v
status "Pass"
#80
test ID  #80
test value 0.0000v
minimum limit 0.5600v
maximum limit 0.0000v
status "Fail"
Did this cheap tool just work out my 02 sensor is flogged ??
its never thrown a code before except for a p0420 from having no cat and bigger exhaust or is this just picking up the second 02 sensor (#80)
  • Puff
  • Member For: 9y 10m 21d
A nb sensor reads from about 0.1V to 1.5V. To see if they're stuffed you watch it swing and if doesn't then it's usually stuffed. The car has to be fully warmed up and it has to be running for longer than 40 seconds to ensure it's in closed loop.
#80 the values never changed, car was up to operating temp it had been driven..
I sort of don't get what you're saying, what does NB sensor mean? is this assuming the o2 sensor is flogged?
maybe this will show more clarity
https://streamable.com/keus2l
https://streamable.com/qubguq
  • Puff
NB is narrow band, it has a very small voltage operating window. WB is wideband and it has a 0 to 5 volt operating range.
If the voltage doesn't move the car is in open loop or the sensor is stuffed.
I can't look at the videos right now
