ChilliDude911 New Member 4 Member For: 5y 17d Posted 08/05/24 12:36 AM Share Posted 08/05/24 12:36 AM My FGX XR6 Turbos airbag light started to come on intermittently, but now it stays on, and due for rego soon. What I have done so far: * Checked all connections under the front seats * Replaced the clock spring with genuine Ford part * Rescanned: showing "Restraint System - Impact Sensor Fault" (see pics showing "Front row impact sensor" (Battery only showing low as I did multiple scans)). The diagram I have seen shows the sensor in the "B" pillar, but after removing the trim I can't see it? There is also an Airbag tag on the seat and the trim if that helps. Can anyone please help me locate the sensors and how to access so I can test them. Thanks in advance Link to comment https://www.fordxr6turbo.com/forum/topic/97263-airbag-warning-light-help-pls/ Share on other sites More sharing options...
