Gaz084 Member 51 Member For: 10y 4m 4d Posted 01/05/24 10:40 PM Share Posted 01/05/24 10:40 PM Hi guys I am looking at pulling the motor out of the turbo territory,oil leaks everywhere....I have pulled out an engine of a falcon bf many years ago. Anything else I need to keep in mind with the difference of it being a territory and a zf? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,031 Member For: 16y 8m 1d Gender: Male Location: Melbourne Posted 02/05/24 12:19 AM Share Posted 02/05/24 12:19 AM only that it's higher... or awd bits if you have that version. Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 4m 4d Posted 02/05/24 02:54 AM Author Share Posted 02/05/24 02:54 AM it is a awd version. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,031 Member For: 16y 8m 1d Gender: Male Location: Melbourne Posted 02/05/24 03:25 AM Share Posted 02/05/24 03:25 AM @Puffwagonwill be able to tell you the differences Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,958 Member For: 9y 10m 12d Gender: Male Location: South Australia Posted 02/05/24 03:36 AM Share Posted 02/05/24 03:36 AM There's no meaningful difference between pulling an engine from a falcon or a territory and awd doesn't affect anything. Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 4m 4d Posted 03/05/24 12:56 AM Author Share Posted 03/05/24 12:56 AM ok thanks gents. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,958 Member For: 9y 10m 12d Gender: Male Location: South Australia Posted 03/05/24 06:25 AM Share Posted 03/05/24 06:25 AM I can give you some tips if you want. Obvious stuff is obvious but some things will save a lot of time. Link to comment Share on other sites More sharing options...
natho Member 10 Member For: 14y 2m 11d Posted 07/05/24 01:56 PM Share Posted 07/05/24 01:56 PM Coming from E series falcons, an engine swap in a BA was a breeze. Everything in the same familiar place, but more accessible. Going to an AWD territory was definitely more cramped. The front diff makes getting to some stuff a little trickier, e.g. starter motor, but otherwise no big deal. The main difference I found was that with the BA/BF, the engine can be lifted straight out. It's a tight fit with the balancer on, but it fits. There isn't enough space in the territory to do this, you need to rotate the engine to lift it out. I've done it a few times and differently each time, but admittedly these were all non turbos. IIRC removing the exhaust manifold and one of the engine mount brackets is enough. Having an engine crane that works properly and can lift to its max height is essential.... I was caught out by this once. 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,958 Member For: 9y 10m 12d Gender: Male Location: South Australia Posted 07/05/24 02:05 PM Share Posted 07/05/24 02:05 PM Haha yerp there's a couple of good tips right there. Balancer off, timing cover toward battery, engine oil in the crane so it actually lifts and undo the bonnet supports so the crane doesn't get stuck on your turbo scoop. Lift engine off the mounts then remove the mounts from the block is another tip. Plenty of things you can do to make it go easy. 1 Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 4m 4d Posted 09/05/24 08:30 AM Author Share Posted 09/05/24 08:30 AM Good advice guys,thank you. Started on this today,I pulled the balancer off and took the radiator out. I remember last time damaging the radiator with the balancer. Do you guys mark the flywhel to the converter? Link to comment Share on other sites More sharing options...
