Caleb New Member 1 Member For: 11m 7d Posted 06/04/24 02:04 AM Share Posted 06/04/24 02:04 AM Hey guys how's it going? I have recently purchased a 2011 XR6t with all the usual mods (Pump gears, valve springs, GTX 3582, etc.) Car is running 611whp. However, I am having some issues with it while accelerating. It seems as soon as I accelerate hard the car revs to 4500rpm then seems to cut power then come back on once it drops below 4000rpm. The car doesn't have any issues when you roll on the throttle and let boost build gradually before flat footing or if you leave traction control on (car is squirrelly though so it does shut you down quite often). My first thought was coil packs but I have changed them all and the spark plugs and haven't seen any improvements. I am currently thinking that it is a fueling issue as the car only has a in tank aftermarket pump (unsure of make model) and is possibly struggling to deliver fuel while the car is building boost. Has anyone had anything similar happen with their car or have any other ideas I should try first? Cheers, Caleb Webb Link to comment Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 1m 21d Posted 06/04/24 09:28 AM Share Posted 06/04/24 09:28 AM Hey Caleb as a starting point you need Forscan 2.4, then Run a KOEO test and a fault code DTC scan before moving forward Have you checked your AFR and fuel pressure ? Link to comment Share on other sites More sharing options...
boostjunki New Member 5 Member For: 10m 3d Posted 10/05/24 06:43 AM Share Posted 10/05/24 06:43 AM Did you find cause? Mines doing similar 1 Link to comment Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 1m 21d Posted 09/06/24 10:25 PM Share Posted 09/06/24 10:25 PM Waiting your reply Caleb Let us know thanks Link to comment Share on other sites More sharing options...
Nailana New Member 3 Member For: 9m 6d Gender: Female Location: USA Posted 19/06/24 06:57 AM Share Posted 19/06/24 06:57 AM Hey Caleb, Your car might be having trouble getting enough fuel when you accelerate hard. See in my opinion, Since you have already checked the coil packs and spark plugs, it could be worth looking into upgrading your fuel system, especially the pump. Have you checked the fuel pressure when you are accelerating? That could give you more clues. and Check out this forum thread where others discuss similar issues and solutions: https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t-mlops-tutorial hope the above will sort it out☺️ Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,190 Member For: 10y 1m 12d Gender: Male Location: South Australia Posted 19/06/24 08:12 AM Share Posted 19/06/24 08:12 AM Based on the initial post it is hitting the boost cut. Verify this by logging and adjust the tune to fix it. Link to comment Share on other sites More sharing options...
