Nick_is_not_sus Member 71 Member For: 1y 8m 18d Gender: Male Location: New Zealand Posted 02/04/24 08:53 PM Share Posted 02/04/24 08:53 PM Hi, just a question, I have a bad injector on number 5 cylinder (picked it up in live data with xtool) I have had the larger injectors for about 5 months now and just wanted to some input. I was going to put the 1250cc injectors in and put the recommended voltages in and reduce the fuel pressure to 3bar. Should these just run like stock injectors till I get it tuned? I still have a little way to go before I go to the tuner. I did search for this question but the answer I wanted to find wasn't there. Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,564 Member For: 17y 2m 10d Gender: Male Location: Melbourne Posted 02/04/24 10:51 PM Share Posted 02/04/24 10:51 PM Extremely unlikely to run like stock injectors... I wouldn't even try something like changing any injector(s) until I was at the tuner. Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722626 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 22d Gender: Not Telling Posted 02/04/24 11:46 PM Share Posted 02/04/24 11:46 PM If you drop it to 1 bar it might run ok. Better to just swap out the stuffed stock injector, they are dime a dozen and someone will probably sell you a set for next to nothing. Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722628 Share on other sites More sharing options...
Nick_is_not_sus Member 71 Member For: 1y 8m 18d Gender: Male Location: New Zealand Posted 03/04/24 12:55 AM Author Share Posted 03/04/24 12:55 AM I guess it might have to be another stock injector. Well I'm pretty positive it's the injector. I put new plugs in and gapped them to .7 still ran the same, swapped coils with cylinder 1 was still the same. Very noticeable on the graph when reving, holding 2000rpm levels out but some exaust popping, taking my foot off the throttle after holding revs the graph on number 5 goes crazy unless I got a bad plug ? Double checked fuel pressure and it's 4bar with out vacum connected. It's not picking up any codes except p0420 and that's cause my cats been taken out I should also mention these both were in drive, first graph idle in drive and second was braking and accelerating loading the car up at around 1800rpm and taking foot off the loud pedal 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722634 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 22d Gender: Not Telling Posted 03/04/24 01:05 AM Share Posted 03/04/24 01:05 AM You can swap one injector for another for a quick sanity check. You may as well just chuck another second hand one in there while you're at it, its up to you how you approach it. Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722637 Share on other sites More sharing options...
xr6tForMe Donating Members 281 Member For: 11y 11m 22d Gender: Male Posted 06/04/24 04:21 AM Share Posted 06/04/24 04:21 AM Could it be intake manifold gasket? Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722671 Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 5m Posted 06/04/24 09:21 AM Share Posted 06/04/24 09:21 AM Give simon a call from injectors online Link to comment https://www.fordxr6turbo.com/forum/topic/97229-new-fuel-injectors/#findComment-1722676 Share on other sites More sharing options...
