purxr6t Member 37 Member For: 4y 9m 10d Posted 20/02/24 09:27 AM Share Posted 20/02/24 09:27 AM Recently purchased a 700+ Rwkw G6E Turbo that is also saying gearbox fault if put in "D" after half an hour or so. It doesn't seem to do it if driving in tiptronic, Although it usually does not seem to go to 6th in tiptronic without pushing shifter over into D. The ZF tune seems a bit rough. At around 40Kmh for example it bucks around into what seems like covertor lock up, Or shifting up and down gears, This is fixed by manually shifting, Down a gear to stop it hunting. It has a Haltech Plug in ECU if that helps. Would like a decent ZF Tune in there, As in "D" it barely drops a gear on the freeway. Supposedly the ZF is built with the bigger Ford Input shaft, And rated at 1000Hp. So can anyone do a decent ZF Tune, that can just be put into "D" for Drag Mode and drive well at that power level? Cheers Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,129 Member For: 10y 17d Gender: Male Location: South Australia Posted 20/02/24 10:22 AM Share Posted 20/02/24 10:22 AM If you're in SA I can help you. Link to comment Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 9m 10d Posted 20/02/24 12:59 PM Author Share Posted 20/02/24 12:59 PM (edited) I am in QLD so along way away, But good that you know that it is possible. Edited 20/02/24 01:02 PM by purxr6t Link to comment Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 9m 10d Posted 23/02/24 12:23 PM Author Share Posted 23/02/24 12:23 PM Any good shops around the Brisbane area that could do a good ZF Tune? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,129 Member For: 10y 17d Gender: Male Location: South Australia Posted 23/02/24 01:21 PM Share Posted 23/02/24 01:21 PM No idea man, have to check FB to see what shops are up to the task. Can you pull the file and flash it back yourself? This would let any shop send you a file, might be worth looking into. 1 Link to comment Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 9m 10d Posted 25/02/24 05:59 AM Author Share Posted 25/02/24 05:59 AM Yeah no worries, I will look into getting PCM Tech most likely. Just that their are some events coming up, So would like to get it all sorted Before the events and that. Cheers I will check it out. Anyone from Brisbane on here that can recommend any shops that can do a decent ZF Tune? Link to comment Share on other sites More sharing options...
