is the BF xr8 zf6hp26 the same as a FG xr6/g6e turbo zf6hp26 ?
Nick_is_not_sus
  • Member For: 9y 9m 6d
Thanks for that. Yeah I did ask the exhaust place to locate it higher up on the pipe but they didn't. Was 5 years ago and the sensor has lasted so no big deal.
But funny enough the narrow band sensor closer to the turbo craps itself every 12m or so.
  • Member For: 1y 3m 26d
having trouble finding a trans but an auto wrecker can and dropped some parts of at work and said they have a few zf6s but no turbo ones.. theres one from a G6E its stamped with 1068 010207 .... mines 1068 010208 looks similar just curious I my valve body/mech will go on and my torque converter onto the input shaft just to keep me mobile till I can get my mine rebuilt
  • Bronze Donating Members
  • Member For: 14y 9d
On 27/01/2024 at 12:08 PM, Puffwagon said:
Have either of you guys ever looked at a ZF box? The trans case is one piece ie the bellhousing isn't separate.
I presumed that was a given.
OP, I presume you're talking about a 6hp19 or 21 box?
Good thing it's stamped on the side of the box.
You checked it's the same case? (bell housing, I don't know puff what else to call it :))
And you were going to swap in your mechatronics?
Yeah this is a different box from another g6e, it was tagged with 2009 ford g6e.
Yeah. I will use my valve and mechatronics. I only just less than 1000kms ago changed seals, new solenoids and zipkit. Not sure if pair the one that's in it with xtool d8? It will just be a temporary trans while I get mine rebuilt. I'm not confident to build the myself..at work any transmission builds we just send the gearbox away we are to busy for rebuilds.
I have another engine I'm getting parts together for this trans won't last .. atomic rods pistons, 274-280/280 kelfords and springs. Head studs 6862 turbo and 2200cc injectors which I and probably going to send back and exchange for 1650cc just a few more bits like pimp gears gaskets and bearings and a donor block and I will be good to go
Oh yeah and I just over the weekend put in a PWR intercooler and took the plazmaman out
