ThomasB New Member 2 Member For: 1y 6m 4d Posted 21/01/24 12:41 AM Share Posted 21/01/24 12:41 AM G’day Everyone, I have recently purchased and fitted the Venom 4” Dump, 100 Cell Cat and replacement Y Piece section. I had a couple of concerns and issues that I thought I’d ask and forgive me if it has been raised before, my main issue is the where the Y Piece meets the Cat and it not marrying up nicely when tightened, it is leaking out the gasket due to not buttoning up nicely on the 2 flanges, has anyone come across this before? And is getting another gasket and having 2 in place a good solution? Also, there are no hangers on the new exhaust section from dump to cat, has anybody encountered any issues from this? Cheers Guys! Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/ Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 7d Gender: Not Telling Posted 21/01/24 11:33 AM Share Posted 21/01/24 11:33 AM Rotate the cat piece or swap it front to back, it may not be in the correct orientation. Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1721847 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 328 Member For: 14y 5m 17d Posted 23/01/24 10:17 PM Share Posted 23/01/24 10:17 PM On 21/01/2024 at 11:41 AM, ThomasB said: Also, there are no hangers on the new exhaust section from dump to cat, has anybody encountered any issues from this? Manta has them. You can easily fab up a tab to retain the block hanger. While you're at it tack on a couple of m8 bolts stacked on one another to pick up the rear heat shield mounting hole. rattle rattle bendy bendy Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1721864 Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 5m 16d Posted 08/03/24 06:49 PM Share Posted 08/03/24 06:49 PM What Series ? BA BF or FG? Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1722369 Share on other sites More sharing options...
ThomasB New Member 2 Member For: 1y 6m 4d Posted 09/03/24 06:41 AM Author Share Posted 09/03/24 06:41 AM Cheers everyone for your reply, Sorted this issue out a while ago I just ended up sanding done the face and getting it flush to have a solid mating surface, I believe that the flange pulled around as it was welded. I chucked some high temperature sealant on it along with the gasket, let it sit for a day and have had no issues since, has been tuned and driven for around 1000kms since fitted. If anyone encounters this issue all I did was get a square piece of steel, sat it on the flange and worked away at the face until there was no air gaps, between the gasket and high temperature sealant that seems to have taken up any other minor imperfections. Thanks everyone! Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1722375 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 7d Gender: Not Telling Posted 09/03/24 10:36 AM Share Posted 09/03/24 10:36 AM Lol I just re-read my advice, there is only one way the venom cat piece can go. I was thinking about my cat piece that is a venom cat but I have modified it so it is literally just the cat only with vband flanges, hence being able to be rotated etc. Oh well Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1722376 Share on other sites More sharing options...
azz Bronze Donating Members 37 Member For: 14y 3m 18d Gender: Male Location: up in the clouds Posted 21/06/24 08:13 AM Share Posted 21/06/24 08:13 AM Why do you reckon Venom didn't include all of the hangers? Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1723345 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,587 Member For: 17y 2m 26d Gender: Male Location: Melbourne Posted 21/06/24 10:36 AM Share Posted 21/06/24 10:36 AM seems like a question for Venom? Link to comment https://www.fordxr6turbo.com/forum/topic/97180-venom-4%E2%80%9D-dump-100-cell-cat-and-y-piece/#findComment-1723346 Share on other sites More sharing options...
