Which brand of TPS
Jeverz
  • New Member
  • Member For: 3y 5m 22d
Genuine Ford, TI Performance, Goss, Tridon.
These are the brands I'm able to find, genuine Ford is twice the price. Am I paying more for quality or  same shiz different label ?
  • New Member
So I ended up cleaning the tps with wd40, reset the ecu and tps and it's soo much better.
I did my sister's first - non turbo and then also did my today - turbo.. and the difference is insane. Both still seem to be the factory tps sensors. Give it a go before buying a replacement
  • New Member
Flooded the inside and then air it out lightly whilst rotating the unit and repeated 3 times on each.
I'm not claiming to be a boss mechanic, electrical wizard or anything.
Give it a go if you have the random stall on startup, this has fixed that issue for my sister's territory. Her idle is much nicer and her instant fuel usage response is back how it should be, it was hella laggy and would never drop when you got off the throttle, it was so slow to react but seems good now and has been for over a week now
