Sniper performance 460 walbro drop in
Gaz084
  • Member For: 21y 6m 8d
On 10/12/2023 at 8:25 AM, Gaz084 said:
Also is the GFB fuel pressure regulator a simple drop in set and forget item?
GFB FX-S Fuel Pressure Regulator for Ford BA BF FG XR6 Turbo Barra 4.0L + Gauge | eBay
The issue you'll have with a drop in reg on the territory rail is if you use a gauge the vacuum line to the brake booster has to be wrenched and zip locked out of the road. I can take a picture of mine but it's not a clean fit not to mention the back fuel injector plug is hard up against it as well. I'm using a turbosmart gauge but even the smaller GFB gauge would no doubt be in the road... If you're going for a fuel pressure sensor later on then I'd just recommend going a remote mounted reg.
