Gaz084 Member 51 Member For: 10y 5m 23d Posted 09/12/23 10:25 PM Share Posted 09/12/23 10:25 PM Hi Guys Looking at modifying my f6x territory, my question is do I need to upgrade the wiring with this drop in kit or will the factory wiring be up to the task? WALBRO E85 460-LPH NEW FUEL PUMP ASSEMBLY FPV SY TERRITORY TURBO 10-2007-ON 4.0L | eBay Also is the GFB fuel pressure regulator a simple drop in set and forget item? GFB FX-S Fuel Pressure Regulator for Ford BA BF FG XR6 Turbo Barra 4.0L + Gauge | eBay Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,180 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 09/12/23 10:41 PM Share Posted 09/12/23 10:41 PM Fuel pressure regulators, assuming it has the same connections, are "drop in". You can take advantage of them partially in the tuning process, though. The 460 will require a wiring upgrade to support it. Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 5m 23d Posted 09/12/23 10:48 PM Author Share Posted 09/12/23 10:48 PM Thanks Kieth. For the 460,is this what everyone is using? XR6 G6ET XR6 TURBO FUEL PUMP WIRING UPGRADE WALBRO 525 460 | eBay Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 5m 23d Posted 09/12/23 11:09 PM Author Share Posted 09/12/23 11:09 PM Another thing,I am only chasing 300-330 awkw do I require the 460 or will the 255 walbro suffice? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,180 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 09/12/23 11:25 PM Share Posted 09/12/23 11:25 PM all-wheel-kilowatts is a different beast and not as well "baselined" for "these mods will get you specifically in the range of X kilowatts"... it depends a lot on the dyno and other supporting mods in the AWD platform... so I'm sure the 460 will make it to the 300-330 range, but not sure if the 255 would. Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 5m 23d Posted 10/12/23 01:35 AM Author Share Posted 10/12/23 01:35 AM ok ,Thanks Kieth 460 it is. Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 1d Gender: Male Location: Perth, WA Posted 11/12/23 05:29 AM Share Posted 11/12/23 05:29 AM I have a 525, I'd recommend going a 460. That way you can save for a dedicated anti-surge system, and the 460 can act as a lift pump 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 7d Gender: Male Location: Canberra ACT Posted 11/12/23 11:15 PM Share Posted 11/12/23 11:15 PM I've got the same reg and gauge. Yep fits straight into the factory rail, same as the factory reg. Just need to set the base fuel pressure to 4 bar with the vac line disconnected and engine running.Personally I found that gauge was spot on for setting the pressure. Swapping from factory reg and then setting pressure via the gauge, my fuel trims were exactly the same. 1 Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 1d Gender: Male Location: Perth, WA Posted 12/12/23 12:21 AM Share Posted 12/12/23 12:21 AM Same same but different, I have the Turbosmart drop-in fpr. I was going to get the gfb one, from memory I think this one was on sale at the time or something. Super easy to install, though my base fuel pressure was off when I installed it, I let the tuna fix that 😋 1 Link to comment Share on other sites More sharing options...
Gaz084 Member 51 Member For: 10y 5m 23d Posted 13/12/23 03:46 AM Author Share Posted 13/12/23 03:46 AM Good info thanks gents. Link to comment Share on other sites More sharing options...
