Bf xr New Member 3 Member For: 1y 2m Posted 14/11/23 12:05 PM Share Posted 14/11/23 12:05 PM Has anyone or heard of anyone putting (or tried to or currently run) 10.5 wide wheels on a bf mk11 sedan? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,138 Member For: 16y 9m 5d Gender: Male Location: Melbourne Posted 14/11/23 09:51 PM Share Posted 14/11/23 09:51 PM If you're talking about the rear, with the right offset and some guard rolling and minor pumping, they'll fit... If you're talking about the front, they won't fit without significant modifications to the front guard (I mean, custom style, I doubt you'd be able to pump the stock guard enough, after rolling it first, without it needing to end up almost flat to clear a 10.5 on a reasonable height car) and a perfect offset to just barely clear the inner suspension (it'll poke a LOT as 9" barely fits on mine on the front with a roll and minor pump of the guards -> https://www.fordxr6turbo.com/forum/topic/96768-tsw-bathurst-on-ba-xr6t-f20x930r20x1040/) Obviously if you run monster-truck height springs, you can fit them no worries with the right offset to clear inner suspension (as they'll just poke and never be hit by the guards), but if you want the guards anywhere near them, it's going to be a challenge to fit them Link to comment Share on other sites More sharing options...
Bf xr New Member 3 Member For: 1y 2m Posted 15/11/23 12:23 AM Author Share Posted 15/11/23 12:23 AM Thanks mate, I might just look for a staggered set of wheels so I can have the front a little low and have good clearance of the wheel. Any suggestions on offset and width for the front? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,138 Member For: 16y 9m 5d Gender: Male Location: Melbourne Posted 15/11/23 12:35 AM Share Posted 15/11/23 12:35 AM First step is do some research on what wheel styles you actually like, then see if they do options that fit Narrow it down from there. Use willtheyfit.com and compare your stock/current rims (usually width is 8in and offset is +36.5, but you can find that out easily enough for your current setup) and compare them to the ones you want. Here's my measurements from that thread I linked for clearances to OEM rims but you can measure your own if you wish. On 08/08/2022 at 1:48 PM, k31th said: Front Inner: ~9mm Front Outer: ~15mm Rear Inner: ~30mm Rear Outer: ~15mm Link to comment Share on other sites More sharing options...
