greasemonkey Member 97 Member For: 7y 6m 29d Posted 17/11/23 07:24 AM Author Share Posted 17/11/23 07:24 AM Appreciate all the advice with the help and service guys, thanks so much!! So I have another question to ask as I will do this job as a one person job. So after draining the pan, cleaning it up and putting on a new gasket, I will remove the filling plug and pump in fluid all the way until it starts dripping out. I leave the filling plug off and then I start the car. After I start the car I shift the transmission into drive first, then neutral and then reverse. I turn the car off, go underneath the car to inspect. I look and check to see if fluid is running out. If no fluid is running out of the fill plug then I continue to pump in more fluid until fluid does come out? I'll call my ford dealer and ask for the unit and its price for the trans cooler. The original one has held up well as it is now 220,000kms so don't mind going stock again (unless it costs a fortune). Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1720996 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 6d Gender: Not Telling Posted 17/11/23 07:31 AM Share Posted 17/11/23 07:31 AM When you start the car after the initial fill it will take another 4 to 6 litres. You have to leave the car running while filling and while the bung is out. If you fill it and switch the car off with the bung out it will piss a whole sh*tload of oil out. So after the pan is back on you can fill it with the car off, then you start it and fill it a whole lot more. Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1720998 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 6m 29d Posted 19/12/23 06:15 AM Author Share Posted 19/12/23 06:15 AM Thanks so much Puffwagon. Sorry about my delayed reply mate. Trying to set up this job sometime in January or February in my garage. Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1721401 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 6d Gender: Not Telling Posted 19/12/23 06:21 AM Share Posted 19/12/23 06:21 AM Haha no worries, happy to help Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1721402 Share on other sites More sharing options...
O Trader Member 89 Member For: 16y 8m 21d Posted 26/01/25 08:42 AM Share Posted 26/01/25 08:42 AM Is there anyway to find out if the transmission Valve Body Separator Plate is a Type A063 orType B063 in the trans without having to open it up. I want to order one prior to the job instead of getting one after its out. TIA. Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1725468 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 6m 29d Posted 27/01/25 01:32 AM Author Share Posted 27/01/25 01:32 AM I don't think so but you can search at Alltranz. Was given this business from members of this forum and it helped me source exact parts for the zf6hp26 trans. I've put a link below for FG falcon trans but check your serial number on the box. Mine ended in 020. https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/ZF-by-Transmission/6HP26/ 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97125-zf-6-speed-trans-oil-service-fg-xr6-turbo-mk1/page/2/#findComment-1725473 Share on other sites More sharing options...
