Help turbo swap from 3582 Garrett to Precision 6235
ULLCEE
  • INFAMOUS
  • Member For: 5y 10m 3d
Hi Guys just needing some help I currently have a 3582 Garrett on my ba xr6 turbo but I'm wanting to swap it over with a Precision 6235,on my current 3582 rear housing I have an external gate fitted,am I able to keep my that housing and use the precision front housing and core?
And also the precision turbo doesn't have water feed line will that affect my car as it's running the factory water lines,will I have to remove all the water lines or just block it off?
any help will be much appreciated as looking to do swap over tomorrow cheers guys
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 8m 12d
You can of course re-use the rear housing, assuming it fits on the core of the 6235.
Yes, just block off the water line exits from the block if your new turbo doesn't need water cooling, or block off the ends of the lines if you don't want to remove the lines themselves... same same.
  • 1 month later...
