PHNTMPHCKHD New Member 4 Member For: 1y 2m 23d Posted 09/10/23 07:09 AM Share Posted 09/10/23 07:09 AM Gday, long time listener first time caller Hope you can help me with an issue. As stated, the problem is in a 5Spd BA XR6 My pedal doesnt seem to want to work until halfway pressed, in which it immediately jumps up the revs I'd assume this'd be an issue with the potentiometer in either the TB, or pedal I have replaced all the intake gaskets and tightened in that ol Fibonacci spiral, cleaned the TB and MAP/F Replaced the TB three times (albiet secondhand units, all worked before I installed them) Replaced my Accelerator with an auto BA XR6 pedal (also secondhand, but functioned correctly last time I used it) I'm short of ideas, besides a wire rubbing through the conduit and grounding out somewhere, but I REALLY dont want to buy a harness, unless its got Haltech printed on it. The codes I have are referring to P0812 - Reverse input circuit: Caused by my LED reverse lights. P1131 - PCM attempting to correct a constant lean P1572 - Brake switch sensor: I bent the bracket, as it wasnt reaching the pedal and activating my brake lights. I suspect the PCM is detecting a discrepency between the two sensors. U1900 - CANBUS fault. Not touching that with a 10 ft barge pole. Suspect it is caused by the canbus module on my Kayhan head unit, but cannot, and will not, be sure. Regardless of all my codes, I cannot think of what can cause this issue. Perhaps the leaning is due to faulty injectors, but at $300< that's not a leap I'm willing to commit to without advice pointing me there. Anyone else have issues like this? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 10d Gender: Male Location: Canberra ACT Posted 09/10/23 08:58 AM Share Posted 09/10/23 08:58 AM I reckon that lean code is where to start looking. I've had a car (albeit a Toyota, not my Falcon) with a similar code. Was a bit easier as it was reporting both banks were lean which eliminated a faulty O2 sensor or blocked injector as they would have triggered just one bank.That car drove a bit the same - sluggish until throttle widened a bit.I reckon if you had a blocked injector it would be running rough. The u1900 is a pretty common code.to get triggered by a scan tool so I think ignore that for now. Things I would try (without being an expert) :-pressure test the fuel system to check for weak pump, blocked fuel filter or faulty reg. Or if your fuel filter is old no harm in putting a new one in anyway. (Fuel filter was my issue. Happened again so I dropped the tank and cleaned it and problem gone)-get a multimeter out and make sure you are getting voltage changes from the pedal and at the TB which will isolate loom/TB/pedal position sensor-check vac lines for damage or loose connections Link to comment Share on other sites More sharing options...
PHNTMPHCKHD New Member 4 Member For: 1y 2m 23d Posted 09/10/23 10:10 AM Author Share Posted 09/10/23 10:10 AM Legend I hadnt considered a voltage check, do you believe the voltage should correlate 1:1 I suppose I could look up what the norm is, hopefully the Haynes has that in it I have a 255 sitting around gathering dust, and a 4bar FPR, though I fear increase rail pressure on stock tune/injectors may cause more issues Ill do what I can and report back in a few weeks/however long I can keep my finger in Cheers for the reply 😁👍 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 10d Gender: Male Location: Canberra ACT Posted 09/10/23 10:20 AM Share Posted 09/10/23 10:20 AM No worries.Not sure on voltage - I *think* they both fluctuate between 0 and 5 volts but someone else might chime in. I think as long as you saw the voltage move as the pedal moves you'd be happy as a first round check.You definitely can't use the 4 bar reg on your NA tune without causing issues. A new reg is only 60 bucks or so but I reckon the reg is less likely to be the problem. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,012 Member For: 9y 11m 3d Gender: Male Location: South Australia Posted 09/10/23 10:26 AM Share Posted 09/10/23 10:26 AM I somewhat recently aka probably 6 months ago, measured the throttle voltages and posted about it. You can see them in forscan anyway. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 10d Gender: Male Location: Canberra ACT Posted 09/10/23 11:48 AM Share Posted 09/10/23 11:48 AM Some bloke said this... https://www.fordxr6turbo.com/forum/topic/96915-tps-diagnosis/?do=findComment&comment=1717500 Link to comment Share on other sites More sharing options...
PHNTMPHCKHD New Member 4 Member For: 1y 2m 23d Posted 06/11/23 03:54 AM Author Share Posted 06/11/23 03:54 AM (edited) Checking back in Replaced Timing chain (Unrelated, but equally pressing issue), both cam sensors, and re-lubed all the seals in the engine The issue persists. Panic bought a new accel pedal, might keep it for a spare, you never know. My next guess on where to go would be fuel pump, then injectors. I want to do the fuel pump, because the thing is just sitting there. I can't rationale putting it in, as I don't have issues starting, nor does it ever feel like the car isn't receiving fuel. The pedal issue merely sounds like 'voltage lag' between the pedal and the injectors. It's like the ECU gets the throttle signal, and just maintains 0% throttle for a second and a half until it decides to limmi and make me look like a flog. I know how an XR6 should feel at however much throttle is being applied, and that's just not what im getting back. I bet dollars to donuts its the bloody injectors, or the entire computer system (ECU, PCM) EDIT: Also measured voltage outputs to both the TPS, and PPS. Both looked in spec, and the voltage was moving 1:1 in terms of movement. (Throttle volts up, TPS Volts down) Range was 0.8 - 3.0 on pedal, and 4.0 - 1.2> on throttle. It was a few weeks ago so pardon if that seems off. Edited 06/11/23 03:57 AM by PHNTMPHCKHD Link to comment Share on other sites More sharing options...
PHNTMPHCKHD New Member 4 Member For: 1y 2m 23d Posted 30/12/24 02:55 AM Author Share Posted 30/12/24 02:55 AM Well to beat a dead horse, here we are. Turns out I had BF cam caps, and BF VCT solenoids. Replaced with BA units and suddenly I have more power Unfortunately the pedal issue is still present. In the end, I believe I know whats happened, to an point. According to PCMTecs Forums, BA's and FG's read throttle position differently by 1 degree. I'm removed the TB and laid it on the rocker cover to inspect movement At 5% throttle, the butterfly valve snaps shut. At 50% throttle, the butterfly valve begins opening from completely closed. Right now I'm working at adapting a BA TB to the FG Plenum. I'll be cutting out a piece of steel plate to seal the manifold, and the TB. Reinstalling the BA Wiring for the TB. AND HOPEFULLY GET THIS POS (which I modified to be unusuable) WORKING AGAIN. 1 Link to comment Share on other sites More sharing options...
