Transmission fault (limp mode)
BrettG6E
  • New Member
  • Member For: 1y 5m
Hi All
looking for much needed help
I have a FG G6ET 2008
I have recently got my car back on the road after building the motor and tuned, iv been to two tuners and they are unable to work it out
I had a standard zf6 which lasted about 300km, I then got a built 6R90 which is going well
it is still going into limp mode when ever I hit limiter and always throws a code P0219 and then locks into 5th gear until the code is cleared
Has anyone experienced this issue and if so what did you do to fix it?
cheers in advance
If someone has the solution that fixes the issue I will happily buy you a carton
  • 4 weeks later...
  • New Member
  • Member For: 1y 5m
Iv tried the above and still getting the fault
I’m in the process of checking sensors now iv replaced Crank sensor and have both CPS on order which I’ll be able to replace today
I’ll let you know if it fixes anything
  • 3 weeks later...
