Ford falcon Xr6 Fg Upgrade Utility 6 sp sports auto
tanacious83
  • New Member
  • Member For: 1y 5m 5d
Hey. So I have a Falcon Xr6 Fg Upgrade Utility 6 sp sports auto and I’m wanting to find out if it is factory fitted 6 speed or had a 5 speed swapped out. Can anyone point me in the direction to find this out? I’ve done the ppsr search but that’s not telling me anything. Any help would be much appreciated.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m
:Welcome2FordXR6t:
Probably best to contact Ford with your VIN number and they should be able to tell you the configuration of your vehicle from the factory. If they don't have a record of it, then it's going to be basically impossible to tell without getting first hand experience from the initial purchaser of the vehicle.
  • Member For: 9y 9m 19d
A couple of years back I emailed foacust1@ford.com with my details and the vehicle details. They can send you a verification letter that confirms exactly what options your car had when it was sold.
Easier way too as Puff says, but the letter is interesting as it it tells you how many were manufactured in your paint colour, with your factory options, transmission etc
  • Puff
  • Member For: 10y 12d
I had a look in the PCMTec tune repository, loaded the file and it shows parameters for the zf6, nothing for the 5r55. Safe to say it's a 6 speed from factory.
  • 3 months later...
  • New Member
  • Member For: 1y 2m 2d
Determining whether your Falcon XR6 FG Upgrade Utility has a factory-fitted 6-speed or underwent a 5-speed swap requires a detailed inspection. Check the vehicle's documentation, such as the owner's manual or build sheet, for transmission specifications. Additionally, the VIN (Vehicle Identification Number) can provide information about the original factory configuration. If unsure, consult a certified mechanic or contact the manufacturer for precise details. They can examine the transmission, identify any modifications, and verify whether the 6-speed is factory-installed or a result of a previous upgrade or swap.
