DSC & TC Errors after Removing and Re-Installing Battery
JECSBHOY1967
  • Member For: 8y 3m 5d
Hello All,
I have a 2013 XR6T Luxury Pack, where the battery was out of the car for about two hours, whilst I was cleaning up around the engine bay. Re-installed battery, start up sequence was OK but it is flashing up DSC and TC warning lights, with a Comms error flashing onto the info screen. After searching or rather researching the errors via Dr Google, I replaced the brake light switch, no change, a short run utilizing slow and fast running will clear the TC issue, but comes back on. I also don't have info relating to range, fuel used, etc.
I am thinking that no power has sparked a fault within the ECU hence it may need clearing with ECU diagnostic tool?
Slainte,
JM
  • [IMPULSIV3]
  • Member For: 5y 9m 17d
Get a scan tool and see what codes are triggering this, could be heaps of things causing it. Maybe you got water inside the fuse box and shorted a fuse?
If you've replaced the brake light switch, double check its installed correctly, needs to be twisted into the correct spot to lock it in place. Its common for people to not install it properly
  • 1 month later...
