JECSBHOY1967 New Member 1 Member For: 8y 2m 18d Gender: Male Location: Brisbane Posted 26/07/23 03:25 AM Share Posted 26/07/23 03:25 AM Hello All, I have a 2013 XR6T Luxury Pack, where the battery was out of the car for about two hours, whilst I was cleaning up around the engine bay. Re-installed battery, start up sequence was OK but it is flashing up DSC and TC warning lights, with a Comms error flashing onto the info screen. After searching or rather researching the errors via Dr Google, I replaced the brake light switch, no change, a short run utilizing slow and fast running will clear the TC issue, but comes back on. I also don't have info relating to range, fuel used, etc. I am thinking that no power has sparked a fault within the ECU hence it may need clearing with ECU diagnostic tool? Slainte, JM Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 8m 29d Gender: Male Location: Perth, WA Posted 28/07/23 07:54 AM Share Posted 28/07/23 07:54 AM Get a scan tool and see what codes are triggering this, could be heaps of things causing it. Maybe you got water inside the fuse box and shorted a fuse? If you've replaced the brake light switch, double check its installed correctly, needs to be twisted into the correct spot to lock it in place. Its common for people to not install it properly Link to comment Share on other sites More sharing options...
Kybus Member 55 Member For: 13y 11m 29d Posted 11/09/23 01:21 AM Share Posted 11/09/23 01:21 AM What scan tool would you suggest? Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 11m 9d Posted 12/09/23 03:53 AM Share Posted 12/09/23 03:53 AM A cheap obd2 tool will be fine for reading and clearing codes. Link to comment Share on other sites More sharing options...
