BF XR6 TURBO OIL IN INTAKE PLENUM
XRBOY85
  • Member For: 3y 2m 4d
Hi guys
My bf xr6 turbo on E85 has oil in the intake plenum about a spoon full every say few 100kms but is coming from the pcv valve hose that goes to the plenum and has done it since purchased the car upon cleaning it then does it again
my plenum is a process west which I removed the top cover to be able to see what is going on
the pcv vacuum hose attached to the bottom/underneath of the plenum nipple as is coming out of the nipple inside the plenum and dripples/pressure out and splashes around but mostly sit running in the corner angle inside the plenum
car runs fine and have done three oil changes on it since owning it over a year or so doing around 7000kms at 151000kms total
oil is clean
water/coolant checked is fine
no oil in turbo
have changed the pcv valve twice/genuine  plastic ford ones and still does it
could it be a blockage in the PCV system creating a lot of pressure as I have a catch can set up also which was on the car when purchased
have attached a few pics of catch can if its set up ok and pcv hose system ?
anyone experienced this type of issue
1bf67a4a043882811f7fd8dbcf04c6b4.jpeg\
thanks
  • Puff
  • Member For: 10y 1m 6d
Running the pcv hose straight to the intake bypasses the catch can and the usual E85 bong water ends up in the intake instead.
It was discussed fairly recently so will be at the top of the search results.
