XRBOY85 New Member 23 Member For: 2y 11m 23d Posted 22/07/23 07:42 AM Share Posted 22/07/23 07:42 AM Hi guys My bf xr6 turbo on E85 has oil in the intake plenum about a spoon full every say few 100kms but is coming from the pcv valve hose that goes to the plenum and has done it since purchased the car upon cleaning it then does it again my plenum is a process west which I removed the top cover to be able to see what is going on the pcv vacuum hose attached to the bottom/underneath of the plenum nipple as is coming out of the nipple inside the plenum and dripples/pressure out and splashes around but mostly sit running in the corner angle inside the plenum car runs fine and have done three oil changes on it since owning it over a year or so doing around 7000kms at 151000kms total oil is clean water/coolant checked is fine no oil in turbo have changed the pcv valve twice/genuine plastic ford ones and still does it could it be a blockage in the PCV system creating a lot of pressure as I have a catch can set up also which was on the car when purchased have attached a few pics of catch can if its set up ok and pcv hose system ? anyone experienced this type of issue \ thanks Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,983 Member For: 9y 10m 24d Gender: Male Location: South Australia Posted 22/07/23 09:52 AM Share Posted 22/07/23 09:52 AM Running the pcv hose straight to the intake bypasses the catch can and the usual E85 bong water ends up in the intake instead. It was discussed fairly recently so will be at the top of the search results. Link to comment Share on other sites More sharing options...
XRBOY85 New Member 23 Member For: 2y 11m 23d Posted 22/07/23 11:03 AM Author Share Posted 22/07/23 11:03 AM had a look in search results but could not find much but will keep looking thanks Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,983 Member For: 9y 10m 24d Gender: Male Location: South Australia Posted 22/07/23 11:17 AM Share Posted 22/07/23 11:17 AM Sixth result down the list Link to comment Share on other sites More sharing options...
