Tom Tucker Donating Members 702 Member For: 5y 10m 5d Posted 26/05/23 11:38 PM Share Posted 26/05/23 11:38 PM I think most of the piston/rod combos are pretty decent. Are you building it yourself? Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718846 Share on other sites More sharing options...
fox1972 Member 47 Member For: 6y 6m 23d Posted 26/05/23 11:56 PM Author Share Posted 26/05/23 11:56 PM Most of the bottom end will be machined and assembled by PLR Racing in brisbane, as well as the head fully serviced. The rest I'll assemble myself. The turbo may have too be replaced as I have a bit of in out shaft play, the bearings do still sound good on shut down though. I was thinking Pulsar GTX3584RS GEN2. All the stuff around the house the missus wanted has finally been completed so she's given me the green light for this build. I was going to try and squeeze out around 350 rwkt's with the existing engine, but I'm not so confident in it holding together, although some have gone a lot higher with out issues. Do it right first time. Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718848 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 10m 5d Posted 27/05/23 02:50 AM Share Posted 27/05/23 02:50 AM That Pulsar turbo is a good option if you replace the stock low mount. Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718851 Share on other sites More sharing options...
hoe Member 77 Member For: 9y 9d Posted 27/05/23 07:52 AM Share Posted 27/05/23 07:52 AM I had je pistons in a stage 3 supercharged rocket 3 I built a few years ago, not a single issue with them @ 390 rwhp. Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718852 Share on other sites More sharing options...
fox1972 Member 47 Member For: 6y 6m 23d Posted 27/05/23 08:07 AM Author Share Posted 27/05/23 08:07 AM I had a 1976 XB 2 Door coupe with a 351 clevo that I rebuilt with with de-compressed JE forged pistions with a B&M under bonnet supercharger with one of the first holley projection systems 25 years ago. It was running the 12psi pulley and this thing was putting out 780hp at the wheels and was a beast. I did a 9.5 at eastern creek with it in 1998 shortly before I sold it. Every year on my holdidays, I would pull the engine out and strip it to check for wear, and those JE pistons were bullet proof. Never ever an issue. Only issue was the occasional bent pushrod. On 27/05/2023 at 2:50 AM, Tom Tucker said: That Pulsar turbo is a good option if you replace the stock low mount. Expand Yeah I want to keep the standard low mount turbo, mainly for the stock looking option rather than the high mount. I was looking at the 6 boost manifold in the standard configuration, only for the option to run an external gate, rather than the mechanical gate on the turbo, but I guess that wouldn't make that much difference anyway. The plan is two have two tunes for this build. 350 - 400 rwkts for daily street use on 98, 500+ and e85 for the power cruise days. Just the spool kits have no real indication of power levels on their website. that's why I'm here asking. I should ask clint my tuner, but he's usually too busy to have a decent conversation with. Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718853 Share on other sites More sharing options...
hoe Member 77 Member For: 9y 9d Posted 27/05/23 08:15 AM Share Posted 27/05/23 08:15 AM My 390hp was a bike, not for the faint hearted.... Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718855 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,336 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 27/05/23 08:23 AM Share Posted 27/05/23 08:23 AM On 27/05/2023 at 8:07 AM, fox1972 said: the spool kits have no real indication of power levels on their website. that's why I'm here asking Expand The cheapest spool kit will do 1000 wheel hp all day long. Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718856 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 10m 5d Posted 27/05/23 01:36 PM Share Posted 27/05/23 01:36 PM You've pushed the spool rods to some impressive numbers! Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718858 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,336 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 27/05/23 01:46 PM Share Posted 27/05/23 01:46 PM I used their I beam rods that are rated to 1200hp. I wouldn't push them past 1800 crank hp unless I was testing lol 😂 Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718860 Share on other sites More sharing options...
fox1972 Member 47 Member For: 6y 6m 23d Posted 27/05/23 05:00 PM Author Share Posted 27/05/23 05:00 PM On 27/05/2023 at 8:15 AM, hoe said: My 390hp was a bike, not for the faint hearted.... Expand lol....would be a hell of a ride.....is it a modified Norton....? On 27/05/2023 at 8:23 AM, Puffwagon said: The cheapest spool kit will do 1000 wheel hp all day long. Expand Ahhh...that's why I was asking. Spool give no numbers. They have a lot of kits, but no numbers. My engine budget is 10k. Like I said...I have the green light from the ministry of finance. Puffwagon,I actually followed one of your earlier threads. You had lots of ups and downs with a build, If I have the right thread. So many here and so many posters. Puffwagon, with your knowledge, if you had 10k to spare, what would you build today.!!! In the 550 rwkt range. BTW thx for your input and knowledge. I really appreciate it. Regards Alan Link to comment https://www.fordxr6turbo.com/forum/topic/96986-advice-on-building-a-new-engine/page/2/#findComment-1718863 Share on other sites More sharing options...
