Snowbear77 Member 102 Member For: 4y 7m 29d Gender: Male Location: Perth Posted 30/04/23 03:14 PM Share Posted 30/04/23 03:14 PM Just within the last week, my dash has developed a 'sound of light crackling, under the dash. It stops ( temporary when I change the vents direction, or change between internal or external ventilation. It dosent stop when I turn the air con unit off. It just keeps on crackling. Once, it kept happening after even removing the keys, but stopped when I locked the car. Sometimes, when I've driven it lately, there's no noise at all. Anybody come across this before........? Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/ Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 29d Gender: Male Location: Perth Posted 01/05/23 09:00 AM Author Share Posted 01/05/23 09:00 AM (edited) Today, the crackling started today as I turned the car to accessories after being parked for 12 hours...........audio was off, air con was off. I got my head down below the steering wheel , and it sounds like it could be coming from the back of the ICC or just to the right of it.....I tried to record it on my phone, though I couldnt hear it when I played the video back...... Edited 01/05/23 09:01 AM by Snowbear77 Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718464 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,425 Member For: 17y 11d Gender: Male Location: Melbourne Posted 01/05/23 09:12 AM Share Posted 01/05/23 09:12 AM sounds like you need to get your hearing checked ... seriously, though, I don't have a clue what could be doing that other than a short that's sparking with a small/tiny voltage... but without a recording we'd be poking in the dark to figure out what's going on... Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718465 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 22d Gender: Male Location: South Australia Posted 01/05/23 09:27 AM Share Posted 01/05/23 09:27 AM On 01/05/2023 at 9:12 AM, k31th said: we'd be poking in the dark Expand I'll poke you in the dark In all seriousness though, the description might point to the issue but I've never pulled a dash out, so couldn't tell you what it is. Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718466 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,425 Member For: 17y 11d Gender: Male Location: Melbourne Posted 01/05/23 09:48 AM Share Posted 01/05/23 09:48 AM On 01/05/2023 at 9:27 AM, Puffwagon said: I'll poke you in the dark Expand sounds enticing Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718467 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 29d Gender: Male Location: Perth Posted 01/05/23 09:56 AM Author Share Posted 01/05/23 09:56 AM Ok, I'll try again for a recording......... Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718468 Share on other sites More sharing options...
hoe Member 77 Member For: 8y 11m 26d Posted 01/05/23 11:43 AM Share Posted 01/05/23 11:43 AM I suspect hvac fan Bearings are flogged out and fan is just touching shroud. Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1718472 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 29d Gender: Male Location: Perth Posted 01/07/23 09:00 AM Author Share Posted 01/07/23 09:00 AM update. The sound stopped completely, until I recently turned the heater on during a cold drive, and the knocking has since been constant in the last 2 days of driving. This knocking is constant even when the air con/heater is completely turned off . If what you suspect @hoe about the hvac, is it a 'dash out' job to replace the hvac bearings? Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1719310 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 29d Gender: Male Location: Perth Posted 01/07/23 10:37 AM Author Share Posted 01/07/23 10:37 AM Could these symptoms mentioned in the previous post be related to the HVAC system? Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1719312 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 23d Gender: Male Location: Perth, WA Posted 09/07/23 01:05 AM Share Posted 09/07/23 01:05 AM Do you have dual zone a/c? If you do, set it to heat and check both sides are hot. If not you may have a broken mixer shaft. They can make funny noises when broken Link to comment https://www.fordxr6turbo.com/forum/topic/96967-sound-of-crackling-in-fg-dash/#findComment-1719403 Share on other sites More sharing options...
