xr605 New Member 14 Member For: 3y 6m 11d Posted 15/04/23 09:01 AM Share Posted 15/04/23 09:01 AM Hey guys Friend of mine just brought a fg xr6 turbo, intake exhaust, stock engine battery relocation kit, exhaust 288rwkw 16psi had a few issues with the coolant pressurising in the system new water pump, hoses,radiator and dayco overflow tried to bleed any air out over half an hour, drove around after topped up then done it again.. I've had it with this car we are now pricing a rebuild thinking lifted the head any final thoughts what it could be? Thanks in advance. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,295 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 15/04/23 10:21 AM Share Posted 15/04/23 10:21 AM 288rwkw is way too low for 16psi... has it been taken back to the tuner or consulting with another tuner? Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 6m 5d Gender: Male Location: Penrith Posted 15/04/23 10:39 AM Share Posted 15/04/23 10:39 AM I had a coolant flush with a new overflow bottle and cap from repco for my FG. Straight after it everytime I stopped it would dump the coolant out the overflow. Tried a new OEM cap and bottle same and then another cap same issue. Mechanic said I had a head gasket. I put the old cap back on and fixed. That was 7 years ago and for the last 2 years its had 470rwkw at 25 psi.. 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 8d Gender: Male Location: South Australia Posted 15/04/23 10:47 AM Share Posted 15/04/23 10:47 AM If it's just pissing out the overflow in the header tank then it's getting too hot. The main reason for that is a faulty thermostat. They can fark out quickly with no warning, so it's worth the $20 to chuck a new one in. Get a thermometer and chuck the old one in a pot on the stove for a sanity check. If the car has been overheated before I'd have concerns about head gasket integrity, but otherwise there is no chance the head was lifted at 16psi. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,295 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 15/04/23 10:49 AM Share Posted 15/04/23 10:49 AM compression check will give you enough knowledge on whether the head-gasket is cooked, too Link to comment Share on other sites More sharing options...
xr605 New Member 14 Member For: 3y 6m 11d Posted 15/04/23 10:50 AM Author Share Posted 15/04/23 10:50 AM (edited) Changed thermostat already mate, I've been told the aftermarket coolant dayco tank caps are rubbish and cause all sorts or problems does anyone know about this issue? Apparently it's doesn't do the same.job as a factory ford cap. 18 minutes ago, gsd112 said: I had a coolant flush with a new overflow bottle and cap from repco for my FG. Straight after it everytime I stopped it would dump the coolant out the overflow. Tried a new OEM cap and bottle same and then another cap same issue. Mechanic said I had a head gasket. I put the old cap back on and fixed. That was 7 years ago and for the last 2 years its had 470rwkw at 25 psi.. Yeah mate, I'm thinking the same thing, those dayco things are rubbish it seems. 36 minutes ago, k31th said: 288rwkw is way too low for 16psi... has it been taken back to the tuner or consulting with another tuner? Got tuned 3000km ago owner said he put this coolant tank in because the old one looked old. 9 minutes ago, Puffwagon said: If it's just pissing out the overflow in the header tank then it's getting too hot. The main reason for that is a faulty thermostat. They can fark out quickly with no warning, so it's worth the $20 to chuck a new one in. Get a thermometer and chuck the old one in a pot on the stove for a sanity check. If the car has been overheated before I'd have concerns about head gasket integrity, but otherwise there is no chance the head was lifted at 16psi. Sorry only pissing out when car is turned off. Edited 15/04/23 10:51 AM by xr605 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 679 Member For: 5y 8m 7d Posted 15/04/23 11:34 AM Share Posted 15/04/23 11:34 AM You can't get the factory caps new any more (or at least supply hasn't been available for around 6 months). I've got an aftermarket cap and overflow without any issues. 1 Link to comment Share on other sites More sharing options...
xr605 New Member 14 Member For: 3y 6m 11d Posted 15/04/23 11:40 AM Author Share Posted 15/04/23 11:40 AM It's probably a Ford dedicated one though. These dayco ones are rubbish Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 8d Gender: Male Location: South Australia Posted 15/04/23 12:01 PM Share Posted 15/04/23 12:01 PM I've had my suspicions about the caps due to things doing stuff, I didn't do the proper testing to confirm though. Link to comment Share on other sites More sharing options...
xr605 New Member 14 Member For: 3y 6m 11d Posted 15/04/23 12:03 PM Author Share Posted 15/04/23 12:03 PM Go buy one from repco the dayco brand then give me feedback Link to comment Share on other sites More sharing options...
