Mox32r Member 34 Member For: 2y 3m Posted 31/03/23 06:10 AM Share Posted 31/03/23 06:10 AM OK seriously now. Is there anything you can upgrade these days that doesn't in turn need everything attached to it either modified or changed???? Just installed the pulsar 3584 gen 2 and there is no way any pipe work will connect to it. How are you supposed to connect it to a filter when it's only like 3inches away from the power steering pump. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,474 Member For: 17y 25d Gender: Male Location: Melbourne Posted 31/03/23 06:28 AM Share Posted 31/03/23 06:28 AM well, it's a turbocharger, of course you need to change some stuff as it's bigger than the OEM one... If you got one that fitted into the OEM housings, then it would have probably fit (maybe not other connections like water/oil/intake etc). Plenty of stuff does "bolt in" in the way you're describing.. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718074 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 31/03/23 06:31 AM Share Posted 31/03/23 06:31 AM On 31/03/2023 at 6:10 AM, Mox32r said: How are you supposed to connect it to a filter when it's only like 3inches away from the power steering pump. Expand 45 degree 4 inch silicone, 45 degree 4 inch ali pipe, 4 inch air filter, relocate battery under driver side headlight. There's kits available or make it yourself. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718075 Share on other sites More sharing options...
Mox32r Member 34 Member For: 2y 3m Posted 31/03/23 07:13 AM Author Share Posted 31/03/23 07:13 AM Yeh I got the antz kit but realised I need to changed the intercooler asweell so it doesn't have both pipes on the driver side. And maybe cutting the 45 way down might work I guess... On 31/03/2023 at 6:28 AM, k31th said: well, it's a turbocharger, of course you need to change some stuff as it's bigger than the OEM one... If you got one that fitted into the OEM housings, then it would have probably fit (maybe not other connections like water/oil/intake etc). Plenty of stuff does "bolt in" in the way you're describing.. Expand Yeh I know, I know. Just frustrated because I guess nobody has upgraded a turbo and left the factory style intercooler. It just impossible for it to work like that. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718076 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 31/03/23 07:20 AM Share Posted 31/03/23 07:20 AM Post a picture so we can see what you're talking about. Although it might seem difficult, it's a fairly simple process to getting this stuff to work. There's enough brain power on this forum to do nearly anything, a pipe install will be a breeze. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718077 Share on other sites More sharing options...
Mox32r Member 34 Member For: 2y 3m Posted 31/03/23 07:29 AM Author Share Posted 31/03/23 07:29 AM That's with the supplied 45. Although I didn't get the 4"-4" just the supplied 3-4 as I thought I was going to do the battery relocation before I did the turbo. I guess Cutting the 45 back towards the turbo will work, but the return intercooler pipe faces that spot. I feel my choices would be make this work, which would be getting an intercooler that exits on the passenger side and preferably a throttle body relocation to not have to Crossover the engine at all, or put the stocker back on after I rebuild it Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718078 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 31/03/23 07:52 AM Share Posted 31/03/23 07:52 AM Do you live in an area where you could get away with using a turbo guard or something like it? That will have it sorted for now until you buy the correct parts to make it all work. I don't recommend chopping up stuff you've already bought, you'll need it later You don't need to relocate the TB, Plazmaman do a pipe kit or whole ass intercooler kits to suit the stock location. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718079 Share on other sites More sharing options...
Mox32r Member 34 Member For: 2y 3m Posted 31/03/23 08:59 AM Author Share Posted 31/03/23 08:59 AM Yehh maybe. I think I'd rather just sell all this sh*t and put the stocker back on. I didn't buy this to spend money so much money on it. Thanks for the advice fellas. I appreciate it Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718080 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,338 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 31/03/23 09:23 AM Share Posted 31/03/23 09:23 AM Yeah man no worries. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718081 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,474 Member For: 17y 25d Gender: Male Location: Melbourne Posted 31/03/23 09:24 AM Share Posted 31/03/23 09:24 AM you were thinking to ugprade the stock turbo to a bigger one, but didn't think it'd cost you a fair bit of money? yikes... either you're a bit lacking in knowledge of how much upgrading a turbo changes things, or you were sold up the river by somebody selling you a "dream". Either way, these cars go seriously hard maxing out the OEM turbocharger anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/96947-turbo-upgrade/#findComment-1718082 Share on other sites More sharing options...
