  • Member For: 10y 3m 17d
  • Gender: Not Telling
Here's my 2c, if you rarely give the car the beans, you may as well get your stock diff refreshed. Will cost less and be suitable for the application.
Bearings are extremely cheap, the removal of the rear cradle and the diff work will cost the most. Get the bushes done while you're there, as the cradle will already be out.
  • Member For: 3y 4d
Removed cradle few months ago and did all the bushings with nolothane ones. Really need to open it up and see what the issue is because it's only ever so often , the other day it went clunk and said no traction and there was no first gear went to seccond then back down to first and it was there fine again loving life was super curious . , clunks square in the middle of diff when I'm aggressive on the gear changes . And often her thuds when I'm turning right from the back left I think it was , only was thinking truetrack so I can give it sh*t and not feel like ima blow the diff 🤣 , I do heaps and heaps of pulls ,
Haha you said you do a burnout twice a year lol.
That last post tells me you might have stuffed coils, very common to cause trans issues, and you might have a stuffed centre bearing which will also go clunk.
Centre bearing will cop it more with stiff diff bushes, will be worth a look.
  • Member For: 3y 4d
Solid bro will definitely look into it , cheers. First time it's ever ever missed a gear like that didn't even make a noise anywhere at the front , clunked In the ass end and 1st was gone , , littarly 5 secconds later when I shifted to seccond then back to first back into full boost was fine ,
Too easy man, plugs need to be gapped correctly because as they wear out the gap gets bigger and puts more stress on the coils, hence the coils failures we see. Failing coils will mess up the trans and dash lights. Just things to check anyway man :)
