  • Member For: 3y 4d
My diff has started to make funky noises some times not often but know it's signs of something back there failing . Wanted to replace it and was curious what'd be best option for being smooth but also can put down good power and do a good burn out when I feel like it *twice a year maybe* , was looking at truetrack gear set but no idea on what one to get .
320rkw abouts . Cheers 2009 fg turbo .
Edited by Jayden7676
Just adding sh*t in
https://www.fordxr6turbo.com/forum/topic/96912-fg-turbo-diff/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 6d
Gear ratio does matter, to an extent, of course... but you can change it if you wish, just make sure you'll be happy with the changes if you go away from a 2.73 (the OEM ratio for an FG ZF).
They'll all work fine with suitable maintenance at your power level.
  • Site Developer
Lowering the ratio means the car will not accelerate as quickly in lower revs but will cruise at lower RPM; the opposite is true of increasing the ratio.
  • Member For: 18y 3m 23d
  On 20/02/2023 at 11:43 AM, k31th said:
truetrac or wavetrac.. either are fine... realistically a replacement OEM one is fine, too.
Expand
Aren't those types a little on the clunky side?
  • Member For: 3y 4d
Was going to replace that too they had a truetrack kit that had both that all comes together
https://www.tuffcarparts.com.au/ba-bf-fg-ford-falcon-fpv-xr6-xr8-m86-eaton-truetra~16117
Was thinking that dunno if it'll fix my stock axels though
  • Member For: 15y 7m 1d
I had a Truetrack fitted on my last Falcon and the new one also has one, every so often - usually after an hours driving - when turning I hear dragging type of sound which I was told was normal for them by a few other Falcon owners at a Cars and Coffee, that I spoke too.
