Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 14/01/23 06:14 PM Share Posted 14/01/23 06:14 PM Hey guys, Recently changed the front shocks in my XR6T 2 months ago. The modified exhaust was hitting the gearbox ( slightly ), and was rectified by my mechanic. Though I've now developed a bumping feel in my accelerator pedal, going over bumps , and sometimes I feel it in my resting foot beside the brake pedal.. Seems very irregular. I've jiggled the accelerator pedal ( every which way ), and seems 100% secure. Anyone had something similar.?...............worse case scenario ( I'm thinking possible rip in the firewall , sway bar rubber, gearbox mount or engine mount ).or something else? Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,422 Member For: 17y 9d Gender: Male Location: Melbourne Posted 14/01/23 10:48 PM Share Posted 14/01/23 10:48 PM you're sure it's in the pedal? Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716685 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 15/01/23 08:36 AM Author Share Posted 15/01/23 08:36 AM definitely feeling it through the accelerator pedal more than any other way. Its quite intermediate when it happens.........I drive to work, the same way ( like most of us do ).........and feel it on 50% of the time. Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716699 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,422 Member For: 17y 9d Gender: Male Location: Melbourne Posted 15/01/23 08:39 AM Share Posted 15/01/23 08:39 AM yeah, based on your description I've got literally zero guesses haha... Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716700 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 19/01/23 12:17 AM Author Share Posted 19/01/23 12:17 AM (edited) It's a real oddity. I've driven 100km since my post above, and all has been good. Just to go over the symptom's better.....when going over pot holes /bumps/train tracks etc, I feel the bump ( excessively )through the accelerator pedal, with sometimes feeling the bump in my left foot beside the brake pedal. It really is an oddity that I cant find anything loose when I have the car jacked or on ramps. The shocks are brand new - ish. Though something is definitely the way is used to be......hence the thought previously, there might be a crack in the firewall, or a weld somewhere has failed. Edited 19/01/23 12:19 AM by Snowbear77 Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716770 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 25/01/23 06:18 AM Author Share Posted 25/01/23 06:18 AM Update.........took it to the mechanic and he suspects the hydraulic engine mounts are failing. They're reacting to the extra heat on our extra hot perth days, giving the difference in driving and unpredictability of feeling bumps. I do have a turbo set-up running a 4 inch exhaust near the engine mount. I've seen the heat shrouds that come from factory, but am aware there are 3 shrouds ( 1 over the turbo, one over the exhaust manifold ( behind the power steering )). Where dose the 3rd mount? Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716899 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,296 Member For: 10y 2m 21d Gender: Male Location: South Australia Posted 25/01/23 06:23 AM Share Posted 25/01/23 06:23 AM On 25/01/2023 at 6:18 AM, Snowbear77 said: Where dose the 3rd mount? Expand Over the engine mount Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716900 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 27/01/23 01:57 AM Author Share Posted 27/01/23 01:57 AM Ok, gonna hunt one down. I'm not expecting a miricale fix with the heat shroud over the engine mount- seeing that the prices for hydraulic engine mounts cost upto $1000 each. Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716933 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,296 Member For: 10y 2m 21d Gender: Male Location: South Australia Posted 27/01/23 04:59 AM Share Posted 27/01/23 04:59 AM Mate that must be a typo, a set of engine mounts is less than $100. Get on ebay and search for "barra engine mounts". A decent mechanic will have them swapped in a couple of hours, so labour should be around $300. If you're a bit handy you can just make a heat shield for the driver side mount. It has a bolt and a stud to hold it in place so easy to attach. Again, just search "heat shield" on ebay and get to origami making. Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716935 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 7m 28d Gender: Male Location: Perth Posted 29/01/23 07:33 AM Author Share Posted 29/01/23 07:33 AM Your right @Puffwagon I dont know what I looked at to see that price ........but the price on ebay is a lot cheaper like you stated. Already found a lower heat shroud for the engine mount. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96883-strange-bumping-in-the-accelerator-pedal/#findComment-1716961 Share on other sites More sharing options...
