Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 12d Gender: Male Location: South Australia Posted 19/12/22 11:08 AM Share Posted 19/12/22 11:08 AM May as well post while the postings good. 766.6awkw or 1028awhp on a roller dyno through an unlocked high stall converter and a built zf. Made that power at 38psi. Here's a run down of the build; Engine It started life as a NA Territory engine, machining by Chris Milton's in Adelaide and assembled at home by me. Stock block decked, torque plate honed, line honed Stock crank ARP 12mm head studs and ARP main studs Hp junkie OS head stud washers Ross Race Series harmonic balancer Atomic flex plate Custom tooled 10mm 6 dowel pin install into crank Spool Drag Pro I Beam rods w/ 7/16 rod bolts Standard size CP Bullet Series pistons w/ OS pins, Cerakote Micro Slick on the skirts and their V Series Piston Coat on the crowns Atomic timing chain kit w/ crank sprocket and posi lock tensioner HP Junkie 10mm girdle w/ main caps machined to fit Stock windage tray minus side supports HP Junkie billet oil pump w/ high pressure relief spring 2006 BF Turbo head, ported Athena split ring head gasket Atomic 0.5mm OS intake and exhaust valves Atomic anti pump up hydraulic lifters Atomic roller rockers Kelford 218-C cams Kelford KVS40-Extreme valve springs w/ titanium retainers Modified stock VCT phasers for limited movement FG rocker cover FG coils Some kinda catch can w/ dual -10 to can and single -12 to intake pipe Hot Side 6Boost exhaust manifold 6Boost 50mm progate into 2 inch screamer pipe, now plumbed back Pulsar 7782 turbo w/ custom 5 inch intake Custom 2 piece 4 inch dump pipe Custom 4 inch exhaust w/ Hooker high flow muffler, resonator and Venom 5 inch cat Cold Side Stock lower half intake manifold w/ Plazmaman top half Plazmaman Territory specific intercooler Custom 3 inch in and out cooler piping Turbosmart Race Port BOV Fuel Stuff Quick Bitz 2200cc @ 4 bar injectors Stock fuel rail modded for dual feed and centre return Turbosmart FPR 2000 2 x Walbro 525 intank pumps w/ dual relay setup Goleby's billet fuel filter Currently on E85 Trans Stuff Modified stock converter for 6r80 input shaft and 3500rpm stall RVO built ZFR80 stage 4 trans w/ billet intermediate shaft and Bluestreak billet planetary Big arse Aeroflow trans cooler Tuning Stuff PCMTec custom operating system w/ launch control, antilag and various other features Custom engine and trans tune by yours truly 4 bar boost sensor 6 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 19/12/22 11:30 AM Share Posted 19/12/22 11:30 AM looks like it might turn a tyre or 4 1 Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 14y 22d Posted 19/12/22 03:04 PM Share Posted 19/12/22 03:04 PM Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 5m 26d Posted 12/09/23 06:47 AM Share Posted 12/09/23 06:47 AM this post is lacking pics PUFF! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 12d Gender: Male Location: South Australia Posted 12/09/23 07:04 AM Author Share Posted 12/09/23 07:04 AM I'll add some if I ever fix it Link to comment Share on other sites More sharing options...
Jeverz New Member 16 Member For: 3y 6m 17d Location: South Australia Posted 04/01/24 03:37 AM Share Posted 04/01/24 03:37 AM On 12/09/2023 at 4:34 PM, Puffwagon said: I'll add some if I ever fix it Fixed it yet? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 12d Gender: Male Location: South Australia Posted 04/01/24 04:42 AM Author Share Posted 04/01/24 04:42 AM Nope. I thought about it once or twice and it's the thought that counts. Link to comment Share on other sites More sharing options...
Jeverz New Member 16 Member For: 3y 6m 17d Location: South Australia Posted 04/01/24 11:03 PM Share Posted 04/01/24 11:03 PM It is what it is Link to comment Share on other sites More sharing options...
