xr6666turbo Donating Members 102 Member For: 7y 7m 27d Gender: Male Location: Brisbane Posted 19/12/22 10:08 AM Share Posted 19/12/22 10:08 AM Coming soon 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 19/12/22 10:18 AM Share Posted 19/12/22 10:18 AM Looks slow Also, can't post in the 400+ section until you have a dyno sheet with proof of it. Moved your thread 1 Link to comment Share on other sites More sharing options...
xr6666turbo Donating Members 102 Member For: 7y 7m 27d Gender: Male Location: Brisbane Posted 19/12/22 10:28 AM Author Share Posted 19/12/22 10:28 AM No worries Not slow 🙃 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 5d Gender: Male Location: Adelaide Posted 20/12/22 01:18 AM Share Posted 20/12/22 01:18 AM Confirmation it’s in the right spot 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 20/12/22 01:44 AM Share Posted 20/12/22 01:44 AM Is that the car? Or are you pulling legs? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 5d Gender: Male Location: Adelaide Posted 20/12/22 03:28 AM Share Posted 20/12/22 03:28 AM No it’s legitimate, I’ll do a write up when the forum isn’t chit 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 30/12/22 05:02 AM Share Posted 30/12/22 05:02 AM moved the thread to the 400rwkw section based on this post's mod list ... even though the video and full dyno sheet both only show 392rwkw it's clearly made 400+ at some stage on that same dyno haha... should we change the sections to "rhkw" instead with the prevalence of tuning via hub dynos haha 1 Link to comment Share on other sites More sharing options...
xr6666turbo Donating Members 102 Member For: 7y 7m 27d Gender: Male Location: Brisbane Posted 30/12/22 06:34 AM Author Share Posted 30/12/22 06:34 AM My job description to Aaron was for 401 rwkw. When he pulled the rocker cover off he rang me and said there was a bit of muck and varnish in there and that we should maybe dial back our expectations in case the old girl couldn’t handle the upgrade. But everything when extremely well, hitting 417 at one point but we decided to dial in back a bit to ensure longevity of components. The end result is as good as I could have hoped for 👌👌 1 Link to comment Share on other sites More sharing options...
xr6666turbo Donating Members 102 Member For: 7y 7m 27d Gender: Male Location: Brisbane Posted 03/01/23 11:47 AM Author Share Posted 03/01/23 11:47 AM Garrett G40-900 - 1.06 housing Vband in/outs 6 Boost new style manifold Turbosmart 50mm Pro Gate plumbed back Plazmaman 800HP intercooler kit Plazmaman Top half polished plenum with FG T/B polished and adaptor plate Plazmaman Single Pierberg UCST Plazmaman HD wiring kit Plazmaclamps Venom twin 2.5* SS Dump back exhaust “Jerra Industries” custom Titanium Pie cut dump and plumb back and Hot / cold side intake pipes Atomic new steel HD oil pump Atomic HD Timing chain assembly Atomic HD M12 Head studs with OS washers Atomic HD lower sprocket Atomic HD valve springs Atomic Stage 2 Cam shafts Atomic HD flex plate kit Ross Racing Gold HD balancer GFB 800 Reg on polished factory rail New Genuine engine mounts New Genuine Alternator New genuine Starter motor New Genuine water pump and metal pulley New tensioner and metal pulley New idler metal pulley ANTZ Performance catch can with Aeroflow SS braid & fittings Red accent washers and new “Allen” hardware Striped bare block/head/sump/pick up/timing cover/ hot tanked /painted/ polished Polished ECU cover/Fuse box cover/Brake reservoir/power steering reservoir cover/hot and cold side pipes on display/turbo comp cover/ Intake/ Thermostat cover/housing/coolant overflow tank Aeroflow HD transmission cooler kit with Thermostatic switch fan custom mounted Full ZF flush / service with GW SYN - TS Aeroflow SS braided Coolant lines with red adaptors Aeroflow fittings to A/N for turbo lines/Drain KPM 1000cc Injectors with electrical adapters GJ DRIVELINES CroMo 1000HP tailshaft with 1350 Uni/Yoke set up Optima Red top tray mounted full custom battery relocation kit with billet battery clamp “Stingray” Push button start kit Genuine Ford new front Hubs Full custom Dyno tuning on 98 fuel with PCMtech software protocol 3 Link to comment Share on other sites More sharing options...
xr6666turbo Donating Members 102 Member For: 7y 7m 27d Gender: Male Location: Brisbane Posted 03/01/23 12:00 PM Author Share Posted 03/01/23 12:00 PM So next on the list is a full closed door respray and some new wheels and tyres. With the wheels, I wanted something special so after a lot of research I decided on getting these beauties made in Japan and shipped out to OZ. They're Work Meister S1r's 11 inch rears and 9.5 inch fronts And for the icing on the cake, so OEM original brand new old stock 1965 mustang wheel nuts from a back woods auto shop in the states 😎 3 Link to comment Share on other sites More sharing options...
