jas98 Member 1,043 Member For: 12y 5m 2d Gender: Male Location: Maryborough Qld Posted 07/12/22 11:52 AM Share Posted 07/12/22 11:52 AM Ba xr6t Running fine for last month no issues after I had a open fault loop issue which was wireing for the 02 sensor way down in wireing loom . Anyway today wife says it started missing just after she left thismorning but came good eventually. When I got home I checked codes and it through all these P0122 P0124 P0172 P0223 P0224 P1131 P1132 U1900 U2197 U2197 These are related to 02 sensor...TPS sensor...pedal sensor....the U ones are aparantly the speed input to cluster not there . I'm lost really. I contacted injectronics and asked them they said it could be pcm but not a common issue these but to check wireing to throttle body and pedal switch . Some say wireing at coils or even coils causing it Everything's new or almost new Has anyone had these codes similar to what I'm getting and found the issue? Link to comment Share on other sites More sharing options...
jas98 Member 1,043 Member For: 12y 5m 2d Gender: Male Location: Maryborough Qld Posted 07/12/22 12:09 PM Author Share Posted 07/12/22 12:09 PM Should be U2197 and U2196 Link to comment Share on other sites More sharing options...
