Snowbear77 Member 102 Member For: 4y 10m 16d Gender: Male Location: Perth Posted 05/12/22 07:00 PM Share Posted 05/12/22 07:00 PM Finally found a set of 19 inch FPV Twists, and now will be finally going the brembo upgrade. I've read in several places that the 6 pot brembo's will fit under these wheels, though the question I have - what is the maximum size rotor I can fit under a set of 19 inch twists? Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,590 Member For: 17y 2m 29d Gender: Male Location: Melbourne Posted 05/12/22 11:19 PM Share Posted 05/12/22 11:19 PM It depends entirely on the bracket that holds the caliper in place how big of a rotor you can go. Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716117 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 10m 16d Gender: Male Location: Perth Posted 06/12/22 05:12 AM Author Share Posted 06/12/22 05:12 AM I found a place that will fabricate the brackets and fit a shiny new set of brembo's. ( if that helps ). I just cant figure out the max size of rotors that can fit under the FPV 19 Twists..... Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716118 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,590 Member For: 17y 2m 29d Gender: Male Location: Melbourne Posted 06/12/22 05:19 AM Share Posted 06/12/22 05:19 AM measure it, I guess... I can't tell you without knowing how they'll make the bracket or fit the caliper test-fit and measure the gap and go with whatever rotors fit inside that sizing. Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716119 Share on other sites More sharing options...
Tom Tucker Donating Members 704 Member For: 6y 8d Posted 06/12/22 07:36 AM Share Posted 06/12/22 07:36 AM The 355mm rotor is designed to fit the Brembos, both 4 and 6 piston front. Going any bigger is pointless because the pad can only engage as much rotor as designed. Plus, unless you go 2 piece rotors, you're adding unnecessary sprung weight with bigger rotors Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716122 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 328 Member For: 14y 5m 19d Posted 06/12/22 09:53 AM Share Posted 06/12/22 09:53 AM For extra inputs sake, I got a set of 355 rotors and Brembo 4 pots here off a FG-X XR8. The diameter part of the equation fit under the stock FG Mk1 18's but the offset part of the equation is a fail. Calliper hits the rim spokes. As mentioned by the brains trust, it all comes down to how the bracket and rotor hat are sized. For what it's worth I've got a set of big pad area AP 6 piston and a 355mm rotor hidden in behind a set of 17's on my HJ ute. What I'm trying to say if you ignoring the blowing my trumpet part, is it all comes down to measurement and employing someone that knows what they are doing. And I'll add another curve ball, for some reason in Australia you will pay mega bucks for a custom brake bracket and rotor hat. From my experience, they can be had significantly cheaper going overseas if you are able to cad the designs up yourself and specify material / tolerances etc. Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716123 Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 4y 10m 16d Gender: Male Location: Perth Posted 06/12/22 06:03 PM Author Share Posted 06/12/22 06:03 PM cheers guys.......thanks for the info. Link to comment https://www.fordxr6turbo.com/forum/topic/96856-brembo-6-pot-vs-rotor-size/#findComment-1716129 Share on other sites More sharing options...
