MattyP MattyP Cruise Control 6,317 Member For: 12y 4m 3d Gender: Male Location: Central Coast Posted 26/11/22 12:31 PM Share Posted 26/11/22 12:31 PM (edited) So after almost a 3 year hiatus I'm back with some turbo barra fun. So join me on resisting the urge to not go silly with it. A very stock 08 Turbo Territory Ghia, Picked it with 250000kms and first thing to do is give it a full once over. Had it on the weighbridge and came in at 2.26T but surprisingly spritely. Fresh thermostat in as the bypass had failed and coolant wouldn't go above 80. Flush oil is in and next is a proper service, Zf Service, Transfer case and both Diff Oils. Also probably in need of a good detail. Only issues I've noted as the front end seems to clunk over bumps so I'm assuming I'm due for some fresh upper and lower control arms. Rear bump stops are looking quiet ratty and new ones on the way. But the absolute most annoying thing was on the drive home after buying it, The bonnet scoop liner blew off on the highway and supposedly ford don't supply them anymore. No wreckers seem to have them so that's great. The most I plan on is some injectors and a fuel pump and E85 as there is a servo right near me. I always thought the G6 was a barge but this things on another level. Anyway enjoy some pics Edited 26/11/22 12:32 PM by MattyP 4 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,609 Member For: 9y 7m 9d Gender: Male Location: South Australia Posted 26/11/22 12:40 PM Share Posted 26/11/22 12:40 PM Go back and look for the scoop, you'll pay $350 for an aftermarket copy. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 4m 3d Gender: Male Location: Central Coast Posted 26/11/22 12:43 PM Author Share Posted 26/11/22 12:43 PM Unfortunately it was on the highway doing 110 and saw someone run over it, Wasn't sure what it was until I got home 45" later. Bloody killed me when I realised Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,609 Member For: 9y 7m 9d Gender: Male Location: South Australia Posted 26/11/22 12:45 PM Share Posted 26/11/22 12:45 PM Territory Crazy is where you'll find a replacement. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,724 Member For: 16y 4m 28d Gender: Male Location: Melbourne Posted 26/11/22 02:18 PM Share Posted 26/11/22 02:18 PM would hardly even be as boaty as the thing next to it 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 4m 3d Gender: Male Location: Central Coast Posted 27/11/22 05:50 AM Author Share Posted 27/11/22 05:50 AM Do the turbo terrys have the same issue with Ball joints as the non turbo series 1s? and are the control Arms the same as the NA ones? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,609 Member For: 9y 7m 9d Gender: Male Location: South Australia Posted 27/11/22 06:36 AM Share Posted 27/11/22 06:36 AM NFI Link to comment Share on other sites More sharing options...
bjc Donating Members 2,819 Member For: 21y 4d Gender: Male Location: Townsville Posted 30/11/22 07:50 PM Share Posted 30/11/22 07:50 PM On 27/11/2022 at 3:50 PM, MattyP said: Do the turbo terrys have the same issue with Ball joints as the non turbo series 1s? and are the control Arms the same as the NA ones? Yes, up until the AWD series 2 SY and from then the geometry was finally changed to the ball joint facing up. The link has everything that is required to change over, pretty sure the abs sensors require shaving down to fit or some mod also https://territorycrazy.myshopify.com/products/ford-territory-awd-syii-conversion 1 Link to comment Share on other sites More sharing options...
