bee30dee New Member 11 Member For: 5y 1m 10d Posted 28/10/22 07:37 AM Author Share Posted 28/10/22 07:37 AM I just did a blow test on the actuator and the end of it feels loose when you blow it all the way and a little loose when it is in Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715302 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 28/10/22 07:45 AM Share Posted 28/10/22 07:45 AM Can you put that into different words or be more clear about what is loose? Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715303 Share on other sites More sharing options...
bee30dee New Member 11 Member For: 5y 1m 10d Posted 28/10/22 07:46 AM Author Share Posted 28/10/22 07:46 AM the bit that connects to the back of the turbo not the fat end but the skinny end Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715305 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 28/10/22 08:17 AM Share Posted 28/10/22 08:17 AM Fark me I don't think that is any more helpful Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715307 Share on other sites More sharing options...
bee30dee New Member 11 Member For: 5y 1m 10d Posted 28/10/22 08:38 AM Author Share Posted 28/10/22 08:38 AM <<<<<<<<<<<ok I changed my picture the circle I put on it is the spot that is loose either the rod or the connecter are loose Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715308 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 28/10/22 08:53 AM Share Posted 28/10/22 08:53 AM Ah gotcha. Yeah nah that's normal for it to move around slightly. Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715309 Share on other sites More sharing options...
bee30dee New Member 11 Member For: 5y 1m 10d Posted 28/10/22 09:45 PM Author Share Posted 28/10/22 09:45 PM question if you put to much pressure into the actuator does it leak air out of the side like a release valve or should it hold pressure Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715316 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 28/10/22 10:55 PM Share Posted 28/10/22 10:55 PM Google how boost control works and you'll have your answer. Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715317 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 322 Member For: 14y 3m 11d Posted 29/10/22 10:54 PM Share Posted 29/10/22 10:54 PM On 28/10/2022 at 9:45 PM, bee30dee said: question if you put to much pressure into the actuator does it leak air out of the side like a release valve or should it hold pressure Expand If you stick 80psi of shop air up its arse it'll relieve itself all alright. The actuator must be air tight. Use a Mityvac or similar home made air regulator plumbed contraption to test it. Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715333 Share on other sites More sharing options...
bee30dee New Member 11 Member For: 5y 1m 10d Posted 30/10/22 08:06 AM Author Share Posted 30/10/22 08:06 AM ty for your help but I found the problem it was the vacuum hose for the fuel regulator had a small split in it Link to comment https://www.fordxr6turbo.com/forum/topic/96834-my-03-xr6t-splutters-between-3-and-4-k/page/2/#findComment-1715340 Share on other sites More sharing options...
