  • New Member
  • Member For: 5y 1m 10d
hi
I'm having a problem with my 240kw Barra
she drives good and changes gears normal up to 3 to 4k runs 6psi
has no folt codes
then when it  hits 3 to 4k revs the motor splutters and the 6 psi turns to 12 psi well the gauge goes up to 12
then the motor runs rough and and smells lean I don't get an engine light come on then I turn it off and restart it and it runs normal
I've replaced the plugs twice the coils 2 tps sensor turbo solenoid
if you could help would be great thank you in advance
Edited by bee30dee
  • Replies 20
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 20d
are you certain it doesn't have injectors, fuel pump, or a wastegate actuator, catalytic converter etc?
  • Puff
  • Member For: 10y 3m 1d
Pretty sure his car ain't gonna make any noises without those items installed :stirthepot:
  • Haha 1
  • New Member
when I bought the car 7 years ago never had a problem 6 months ago it starter doing the splatter thing
oh and it has a muffler delete
Edited by bee30dee
  • Site Developer
could be a collapsed cat... e.g. with a small amount of flow (lower revs) it doesn't obstruct the flow but once it gets into higher revs with the same boost level there's more air flowing through per second and it gets blocked a bit so the turbo gets more backpressure and spikes the boost up higher than it should... only a guess, though. Best to take it to a dyno/mechanic and run it up to see what it's doing.
  • Site Developer
The stock exhaust is 2 1/4 inch twin after the cat. If it's aftermarket, it could just be cat-back, but if it's dump or cat + cat-back, it can cause issues with a stock tune.
  • Puff
Mebbe a rooted actuator? The diaphragm could be stuffed causing it to overboost.
